AW: [Doepfer_a100] Is my filter faulty (A101-1 Vactrol)?
2009-07-20 by yahoo@doepfer.de
> Hello > > First time on this forum. > > I've just bought a Doepfer modular and I'm have a slight problem > with the A101-1 Vactrol filter. > > Whenever I connect anything to one of the CV inputs I get a lot > of background noise/interference. This happens even when the > corresponding CV control is zero and even when connecting to > sources with no control voltage output (e.g. mixer input or reset > on LFO)- so its not CV opening the filter. > > Any ideas anyone? > > Cheers > > Carter That's a very unusual behaviour because zero CV should be the same as an open CV connection. I'd recommend to return the module for repair. I have never heard of such a behaviour (i.e. connecting zero Volt CV that affects the sound) and have no idea what could be the reason (maybe it a problem with a GND loop ?). Best wishes Dieter Doepfer
