Doepfer
sawtoothing the rectangle
2009-07-29 by Stu Grimshaw
hi group,
been having lots of fun with the a113 subharmonic generator in the last few days, and i've been wondering how the rectangle to sawtooth conversion works.
any tips?
cheers,
stu
AW: [Doepfer_a100] sawtoothing the rectangle
2009-07-29 by yahoo@doepfer.de
> hi group,
> any tips?
> cheers,
> stu
A capacitor is charged by a voltage controlled current source (VCCS) and
reset by the falling edge of the rectangle. The control voltage of the VCCS
is generated by a simple frequency-to-voltage converter (nothing but a
one-shot multivibrator triggered by the rectangle and a passive low pass
filter). Far away from beeing a perfect sawtooth (same as the original
Trautonium) but the right choice for this application.
Best wishes
Dieter Doepfer
Re: sawtoothing the rectangle
2009-07-30 by Stu Grimshaw
cheers dieter.
i'll have to do a little research to find out what some of that means, particularly the multivibrator, but that's part of the fun.
anyway, the a113 is a great module. the tones available by using the upside down harmonic series are really worth having.
is there somewhere on the pcb where one could tap the square waves before they get sawtoothed? i'm putting a rack together based around the a113 and the a107, and the extra waveform would be a useful extension. or so i assume, it's early days yet :)
thanks,
stu
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] Re: sawtoothing the rectangle
2009-07-31 by yahoo@doepfer.de
> cheers dieter.
> thanks,
> stu
The rectangles are available as the port outputs RB1...RB4 (pins 22...25) of
the microcontroller. If you want to use these at outputs you have to insert
protection resistors (~1k) between the corresponding pin and the sockets.
Otherwise the microcontroller may be damaged when a plug is inserted into
the socket (because of the short circuit that is generated for a short time
when the plug is inserted).
Best wishes
Dieter Doepfer
2009-07-31 by Stu Grimshaw
great, thanks for the reply.
stu
> Best wishes
> Dieter Doepfer
