Doepfer
Using an A192 with a Seqencer
2009-08-19 by stuadh
Yes,
  I, too, fell for it.  I bought an A192 hoping to use it to record sequencer patterns, like it says in the user manual, but it turns out that you can't record Note on/off data, so it doesn;t seem to be much use.
  Now, I know the A192-2 is coming out sometime, but I'd like to know if anyone knows how to set-up the A192 to somehow be usable as a sequence recorder within Logic?  I have the Pocket Editor programme, although I'm still trying to work it out.
Yours Aye
Stuadh
Re: [Doepfer_a100] Using an A192 with a Seqencer
2009-08-19 by Florian Anwander
Hi Stuadh
Transform the data in Logics environment in realtime (either while
recording or in playback).
Florian
Re: Using an A192 with a Seqencer
2009-08-20 by selfoscillate
hello stuadh,
as a counterpart of the discontinued a191, the a192 is
designed to convert control voltages into midi controller
data, it cannot process note/gate information.
if you want to do something like that you have to design
an environment in logic that transforms the data.
i cannot tell you how to do it best and if it is practical
anyway, but i think it is possible. it's been many years
ago since i messed around with data transformation in logic,
i simply have forgotten all the tricks.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "stuadh" <stuadh@...> wrote:
> Yes,
> Yours Aye
> Stuadh
2009-08-21 by stuadh
OK, thanks.  Thinking Cap on because I'm rubbish at the Environment page in Logic.  I generally avoid meddling because I just don't get it.  In fact, I don;t even know how I got my current set up to work...it just does.  Or is that, it does, just?
Stuadh
--- In Doepfer_a100@yahoogroups.com, "selfoscillate" <synaptic_music@...> wrote:
> hello stuadh,
> best wishes
> ingo
> --- In Doepfer_a100@yahoogroups.com, "stuadh" <stuadh@> wrote:
> > Yes,
> > Yours Aye
> > Stuadh
