Doepfer
analogue systems rs370 in doepfer case
2009-10-13 by Ancient Eyeball Recipe
Actually, a monorocket case, but my concern is the same.
Can anyone verify that the rs370 + rs375 adapter will work?
Gene
Re: [Doepfer_a100] analogue systems rs370 in doepfer case
2009-10-13 by Bakis Sirros
IIRC, the RS370 needs the +5 Volts supply, indeed.
confirm with Bob Williams
though!
also, i think it may need more than 100mA's in +5 volts, so, probably, the Doepfer +5volts adaptor will not be enough... but ask Bob to be sure.
and indeed, its a unique module. recommended for sure!
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Tue, 10/13/09, Ancient Eyeball Recipe <implode7@comcast.net> wrote:
From: Ancient Eyeball Recipe <implode7@comcast.net>
Subject: [Doepfer_a100] analogue systems rs370 in doepfer case
To: doepfer_a100@yahoogroups.com
Date: Tuesday, October 13, 2009, 8:41 AM
Gene
