A-111-5 filter tracking problems
2009-10-29 by phono 1337
Not sure if this is normal behaviour or if i have a faulty unit. I have a couple of mfb power supplies/midi cv converters and i've tried with both and they both yield the same results. The problem is this, when using the internal bus, notes play at the correct pitch and gate fine but VCF tracking doesn't work at all regardless of the switch position. However if i connect a cv cable from the front panel to the VCO F socket then filter tracking works as expected, i wonder if this is a problem with the mfb design or a problem with my A-111-5, any ideas? Paul
