Subject: [Doepfer_a100] Re: a154 doubt
Date: Sunday, November 1, 2009, 7:57 PM
ok, Bakis
i didn t understand the principles of the first & last knobs, sorry for my impatience!, now i m happy again.
efgaristó
miguel
--- In Doepfer_a100@ yahoogroups. com, Bakis Sirros <synth_freak_ 2000@...> wrote:
> hi Miguel,
> assuming that you have flipped the 'master' switch that enables the A154 to control the a155:
> you do have pushed 'start' in the a154 ?
> you have not put the a154 running mode into one of the 'one shot' modes?
> you have not put the a154 running mode into the 'cv control' mode?
> you do have the 'first step' knob full CCW and the 'last step' knob CW?
> you do NOT have a constantly high gate signal into the reset input of the a155 or the a154?
> then, if all these are right, and you have connected the a155 to the a154 correctly and the a155 is not stopped (just press the start button on the a155 as well, to be sure), the a155 should run with the speed of the a154 clock...
> Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
> [Doepfer_a100] group owner
> www. parallel - worlds - music. com
> www. myspace. com/ parallelworldsmusic
> www. myspace. com/ interconnectedmusic
> www. myspace. com/ memorygeist
> www. DiN. org. uk
> www. musicamaximamagneti ca. com
> www. shimarecords. co. uk
> www. rubberrecords. gr
> Athens - Greece
> --- On Sat, 10/31/09, miguel <ventrality@ ...> wrote:
> From: miguel <ventrality@ ...>
> Subject: [Doepfer_a100] a154 doubt
> To: Doepfer_a100@ yahoogroups. com
> Date: Saturday, October 31, 2009, 11:04 PM
> hi friend, i need a bit of help
> recently i installed the a154 controller to drive my a155, i think the connections between are ok (everything seems to be right, clock speed flashing, etc),but when i press start in the a154 the sequencer don t run, have i to connect any patch apart from the cv- gate usual ones? i used the a155 alone with no problem at all...
> many thanks in advance
> miguel
