I've decided to startup with a Dopfer A100 modular but my actual budget is about 500-660 euro so i need some advice about the first series of module to buy.
thanks in adavnce
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello!
I'd go for a synthesizer voice if I were in your position now. It costs 300 euros and it have everything you need for a basic modular except a MIDI-CV converter and a case, but 360 euros that you will have left will be enough for those.
Best regards, Mikhail
> thanks in adavnce
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkrvylkACgkQPHyh4sfuKrmaogCeIQXcWgQMO+zYltUpNAJcpfyA
1KwAn2NiMR9xBmeG/CjsR3eJU7OxIdPW
=pj81
-----END PGP SIGNATURE-----
this is what i started with, its a great little module to begin with
On Tue, Nov 3, 2009 at 8:13 AM, amsonx <amsonx@yahoo.com> wrote:
> Thanks for your advice, this solution seem a good startup for this price,
> de facto is a Dark Energy.
Hi
> Thanks for your advice, this solution seem a good startup for this price, de facto is a Dark Energy.
I also would recommend an A111-5. You should consider also that you need
a housing with powersupply; and this will be the most expensive part at
the beginning. The cheapest in the Doepfer range is the A-100LC6 with
240 Euros - except you go the DIY way: A-100DIY1 for 120 Euros. But
accounting the time and effort to build the real case, the A-100LC6
would be cheaper.
Florian
yes iment to write that the a-111-5 was what i started with not the dark
energy (albeit the same thing)
On Tue, Nov 3, 2009 at 3:23 PM, amsonx <amsonx@yahoo.com> wrote:
> Thanks to all for the clean and quickly answers.
> Diego
