Doepfer
Microtuning for A-190-3 ?
2009-11-19 by glabbeur
Hello Dieter !
Since the A-190-3 will have an USB port and a LCD it would be a great addition to be able to load microtuning files ( Scala )
Info about the format here : http://www.huygens-fokker.org/scala/scl_format.html
http://www.huygens-fokker.org/scala/help.htm#mappings
99,9 % of scl files already created ( around 4 000 ) weight less than 1 ko so maybe a small memory to keep the ones you use in the module.
Also it depends of the numbers of characters displayed in the LCD since some file names can go up to 20 characters max ( but very few of them )
Thanks for considering !
AW: [Doepfer_a100] Microtuning for A-190-3 ?
2009-11-20 by yahoo@doepfer.de
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von glabbeur
> Gesendet: Donnerstag, 19. November 2009 19:59
> Betreff: [Doepfer_a100] Microtuning for A-190-3 ?
> Hello Dieter !
> few of them )
So far there are no plans for microtuning. I'll ask Christian if there is a
chance to add this feature. If there is sufficient memory left the main
problem will be to define the scale and to transfer it to the module !
Best wishes
Dieter Doepfer
Re: Microtuning for A-190-3 ?
2009-11-23 by cameron
Another vote for microtuning via uploading Scala .scl files via USB!
That would be fantastic.
> > Hello Dieter !
> > few of them )
> Best wishes
> Dieter Doepfer
