Doepfer
FS: (USA) Euro Modules: Doepfer, Elby, A.Sys, A Sol and some Frac
2009-12-28 by p. hendricks
Trying to make some room, so here's some bits for sale!
All modules ship with mounting screws and power cable(unless passive)
Payment: Paypal, Check or Money Order
Shipping(from Seattle, WA USA):
in USA $6 base +$1 for each additional module. Will ship USPS or FedEx Ground(depends on weight and destination)
in Canada ask for quote, starts at about $23 Priority USPS insured
in Europe ask for quote, starts around $32(last I checked) Priority USPS insured
list
DOEPFER
A-106-1 Xtreme Lowpass/Highpass Filter(ms20 type+) $118 each(2 available)
a-115 audio divider   $60.00
a-124 vcf5 / "wasp" filter  $76.00
a-130 LINEAR voltage controlled amplifier $61.00
a-131 voltage controlled amplifier (exponential) $62.00
a-138a LINEAR mixer  $53.00
a-138b Exp. Mixer  $53.00
A-140 ADSR Envelope Generator  $68.00
a-142 voltage controlled decay/gate   $70.00
a-143-1 complex envelope generator/quad ad-generator/quad lfo  $190.00
A-144 Morphing Controller   $57.00
A-145 Low Frequency Oscillator LFO   $62.00
A-147 Voltage Controlled Low Frequency Oscillator VCLFO  $79.00
a-162 dual trigger delay   $60
a-172 maximum/minimum selector   $50.00
a-189-1 voltage controlled bit cruncher / modifier    $105.00
ELBY DESIGNS
cgs721 super psycho lfo  $159.00
cgs758 utility lfo   $139.00
Analogue Systems  rs160 CV Mixer (w/doepfer cable only)   $59.00
Analogue Systems  rs95 VCO (w/Doepfer cable only)   $169.00
Analogue Systems  rs95 VCO (w/ A. Sys cable only)  $169.00
(may have an extra adaptor to Doepfer add $15)
Analogue Solutions:
SY02 (ms20 clone)Multimode Filter with VCA $132
EG02* Dual Env with Manual triggers and Bi-polar mix $138(important:see notes/detail below)
+FRAC rack format:
list
BLACET (all are Blacet assembled-not kit, unless indicated):
MX2040A    Mixer/Processor  $89
EG2070A    Envelope Generator $131
BZ2300A    Binary Zone $139
WC2700A    Window Comparator  mounted NEVER used $92
FD2020     Freq. Divider (no longer made) $198
Multi2210A   Multiple/Attenuator (assembled from kit) $20
METALBOX
CGS Psycho LFO x2
$79 each.
Oozitronics- Pair-o-slopes
(2-CGS slope detectors) in Frac.
$148
-------------End of List-----------
Thanks!
-phil
*EG02(no longer made-note: "repeat" on env. #2 never kicked in, needs a
resistor value swap according to Tom @ AS)
Very cool Dual env. with dual manual triggers:
Dual Envelope Generators with mixer and EMS-style repeats
Width 18HP
2x ADSR envelopes. Each has manual trigger button, positive output, variable
negative to positive outputs.
Each EG has A, D, S, R and Level
(- to +)
Each EG also has and EMS-style Repeat function (when sustain set to zero and
key held down) - this is an easy to use and powerful feature. There is also
an output that is the mix of EG 1 + 2 - great for both EGs controlling 1
destination.
Each EG has Trig In, + Out, - to + (variable) Out.
Also separate + and - Mixed outputs (EG 1+2)
