Thank you very much!
Do you maybe know which modification?
Or where I could find specs to the CEM3394?
Olli
--- In Doepfer_a100@yahoogroups.com, phono 1337 <phono1337@...> wrote:
> not without modification, theres a few extra output pins but osc out isnt
> one of them
> Paul
> On Thu, Jan 14, 2010 at 6:27 PM, okmog <olli@...> wrote:
> > Hi,
> > does anybody know, if it's possible to braze a separate VCO output of the
> > A-111-5?
> > Ollie
I've found the datasheet of CEM3394:
http://www.datasheetarchive.com/datasheet-pdf/012/DSA00198797.html
There is a diagramm on the last page. It seems that it's probably not possible, is it?
Ollie
--- In Doepfer_a100@yahoogroups.com, "okmog" <olli@...> wrote:
> Hi,
> does anybody know, if it's possible to braze a separate VCO output of the A-111-5?
> Ollie
one of them
On Thu, Jan 14, 2010 at 6:27 PM, okmog <olli@lalug.de> wrote:
> Hi,
> A-111-5?
> Ollie
> Hi,
> Ollie
As the A-111-5 uses the CEM3394 there is no separate VCO output available.
One the triangle would be available if the signal of the frequency capacitor
of the CEM3394 is buffered.
Best wishes
Dieter Doepfer
