Doepfer
A-187-1 DSP Effects Available
2010-02-06 by Oliver Gretz
I've just seen that the A-187-1 Voltage Controlled DSP Effects is available right now! :)
Ollie
Re: [Doepfer_a100] A-187-1 DSP Effects Available
2010-02-06 by Bakis Sirros
yes, it is available now, you beat me to it.
i also wanted to announce that.     :-)
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
www. shimarecords. co. uk
--- On Sat, 2/6/10, Oliver Gretz <olli@lalug.de> wrote:
Subject: [Doepfer_a100] A-187-1 DSP Effects Available
Date: Saturday, February 6, 2010, 3:24 AM
Ollie
2010-02-09 by Joachim
I hope the manual will be released soon.
Would like to know what this module does exactly and what the
specs are (24 Bit, 44,1 KHz?).
Joachim
Am 06.02.2010 um 02:24 schrieb Oliver Gretz:
> Hi,
> Ollie
AW: [Doepfer_a100] A-187-1 DSP Effects Available
2010-02-10 by yahoo@doepfer.de
> Hi,
> Joachim
The DSP board data sheet says 24 bit/48 kHz. We are about to update the
A-187-1 info page as Christian added also some more effects like VC
equalizer.
Best wishes
Dieter Doepfer
> > Hi,
> > Joachim
> equalizer.
> Best wishes
> Dieter Doepfer
To be on the safe side I asked the manufacturer because different versions
of the DSP board are available. The board we use in the A-187-1 has these
specs:
AD/DA converter resolution: 20 Bit
Internal processing: 24 Bit
Sample rate: 32 kHz
Best wishes
Dieter Doepfer
2010-03-13 by John V. Talbert
Just curious, has anyone seen this module for sale anywhere yet?  I've
checked six online retailers so far and there's no sign of it, even
after 5 weeks.  Or maybe I'm just too anxious!  :->
John
On Wed, Feb 10, 2010 at 7:20 AM,  <yahoo@doepfer.de> wrote:
>> > Hi,
>> > Joachim
>> equalizer.
>> Best wishes
>> Dieter Doepfer
> specs:
> Sample rate: 32 kHz
> Best wishes
> Dieter Doepfer
