Doepfer
Doepfer A-155+A-154+A-156 or Analogue Solutions Oberkorn sequencer?
Re: [Doepfer_a100] Doepfer A-155+A-154+A-156 or Analogue Solutions Oberkorn sequencer?
2010-02-14 by J S
I think the mentioned modules will give you a much bigger range of
possibilities than any of the other two.
More possibilities is making more choices.....don't know if that is what
you're after.
2010/2/13 fbertran5 <fbertran5@yahoo.es>
> Hello.
> What do you think?
> Or maybe a Doepfer Maq 16/3?
> Thanks everybody.
Re: Doepfer A-155+A-154+A-156 or Analogue Solutions Oberkorn sequencer?
2010-02-14 by fbertran5
Hi JS.
Thanks.
Every sequencer (Oberkorn/Doepfer set and Doepfer Maq)has its pros and cons.
I've got a Roland System 100M-D and I'm looking for a sequencer, and I've thought that the Doepfer set I've mentioned in a Doepfer case would be good as I also could expand it with more modular modules (in the future).
I got a MFB-Step 64 and it's good for midi but not for CV (it doesn't tune well the pitch of the sequences/bad scale)and also is so limited in amodular setting.
Maybe you can tell me about more analog sequencer options.
Thanks again.
> you're after.
> 2010/2/13 fbertran5 <fbertran5@...>
> > Hello.
> > What do you think?
> > Thanks everybody.
Re: [Doepfer_a100] Re: Doepfer A-155+A-154+A-156 or Analogue Solutions Oberkorn sequencer?
2010-02-14 by J S
I have a A155 which I really like, but you need the expansion module to get
the best out of it.
It will give you pendulum and random and longer/shorter sequences.
 I ordered a TipTop audio Z8000, which looks like one of the best sequencer
ideas ever.
And .....I'm having a Klee sequencer built for me, I'm really looking
forward to that one.
I used to have a korg sq10, but thought it was way to limited. At the moment
I'm using an old drummachine to trigger my modulars.......instant fun.
2010/2/14 fbertran5 <fbertran5@yahoo.es>
> Hi JS.
> Thanks.
> cons.
> setting.
> Thanks again.
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>, J S
> > you're after.
> > > Hello.
> > > What do you think?
> > > Thanks everybody.
