Doepfer
introducing ADDAC System - arduino based analog->digital->analog
2010-02-19 by andre goncalves
Hello all,
so arduino meets 16bit 8 channel CV output
(this are NOT PWM outputs!)
I've been building this modular system for digital generation of complex
waves based on math equations, this is also meant to be a platform to
integrate the analog world to a computer for higher resolution applications
where midi isn't precise enough, so it has a 10bit ADC (0-1023) and 16 bit
DAC (0 -65535)
It is also a standalone tool, no computer is needed to run it, after the
code is uploaded with all the functions assigned it's just another module on
the cabinet
a truly open interface based on the arduino platform, with basic control
through java programming and full control with c++
although it's not all finished yet, all electronics are assembled and
tested, but still a lot more programming to do in the arduino library to
make everything easier for low level programmers, still i thought of posting
this here to get some reactions before making everything available.
in the next couple weeks a lot more info will be added to the site,
including more pictures, demonstration videos and a lot more info
it's hard to describe the whole concept briefly
please take a look at:
http://www.andregoncalves.info/addac
soon it will be hosted here:
http://www.addacsystem.org
get in touch
best
andre
