Doepfer
Another Newbie Question: Is my module dead?
2010-02-23 by stevebdar
I installed all the Doepfer modules in my new case, along with my 2 Livewire modules.  Everything seems to work properly except when I try to use my VCO A110.  If I add a plug to it, all the lights on the other modules turn off.
Does this mean the module is dead?
Thanks
Steve B
Re: [Doepfer_a100] Another Newbie Question: Is my module dead?
2010-02-23 by Bakis Sirros
are you sure you connected the A110 correctly to the busboard? (redstripe down on the doepfer busboard) and is the module end of the ribbon connected correctly to the a100 pcb too?(red stripe to the -12volts mark)
if yes, describe the patch you created in detail.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
www. shimarecords. co. uk
--- On Tue, 2/23/10, stevebdar <stevebdar@yahoo.com> wrote:
Subject: [Doepfer_a100] Another Newbie Question:  Is my module dead?
Date: Tuesday, February 23, 2010, 4:40 AM
Thanks
Steve B
2010-02-23 by Steve
Hi Bakis:
Thanks for the advice.   Since I had bought this through eBay, I was careful with the any modules to make sure red strip was correct.  What I didn't check on some of the modules was if the strip was correct on the modules!  That was where the problem was on the a100.
Steve B
--- On Mon, 2/22/10, Bakis Sirros <synth_freak_2000@yahoo.com> wrote:
Subject: Re: [Doepfer_a100] Another Newbie Question: Is my module dead?
Date: Monday, February 22, 2010, 11:43 PM
www. DiN. org. uk
www. musicamaximamagneti ca. com
www. vu-us. com
To: Doepfer_a100@ yahoogroups. com
Thanks
Steve B
