> Hey!
> What should I do when I want to use Doepfer MCV24 115V version in
> Europe (230V)?
> Is it a simple modification inside the MCV24 or should I just buy
> a step down (230V to 115V) converter?
> Thanks,
> ysi
If you are familiar with electronics I could send you a technical document
that described how to modify the MCV24 for 230V. These notes are intended
for experts only. Carrying out of works described in this document is
allowed only for authorized personnel who are familiar with all valid safety
rules. Laymen are not allowed to carry out these works ! Danger to Life.
Please contact me directly (hardware@doepfer.de) if applicable.
Otherwise please use a step down converter. I'd also recommend the use of a
step down converter if you plan to use the MCV24 in 115V countries again. It
takes at least 30 minutes to modify the MCV24 for 115V. The 230V
modification should be carried only if the unit will be used for a long
period in Europe.
Best wishes
Dieter Doepfer
