Hello Florian
First of all thanks for taking time and answering me !
Today i did exactly what you wrote here. I took all the audio and electricity cables out .
My experience with modular system follows ;
Lets say;
-you have a module in case A
-you have same module also in case B
- And you have your outputs going to your mixing console from case C
When you connect the module in case A to case C , there is a hum .
When you connect same module but from case B to case C , there is no hum .
And sometimes if a module is making hum from Case A , when the time you connect another module from Case B somehow killing the hum coming from Case A .
Another example ;
lets say you have Cwejman MX4S mixer in Case A
And on Case C you have Cwejman AI
When you connect them each other , there is no hum , but when take something from Case B to MX4S where it is connected to case A , with this chain , output from Case C is also starting to make hum .
Seems like modules each other are able to kill the hum , but also modules each other are also creating the hum .
If Cwejman MX4S mixer is on high volume, but no signal inside , this is reducing the hum coming out from AI2 .
But when you start to volume down the channels of MX4S , hum is getting higher again .
As summary , hum is getting high and low also if you start to play the volumes of the devices .
Is it normal ?
In this case , grounding 4 Doepfer cases are sense ?
If yes , what is the proper method to do it ? I have exactly the same yellow green grounding cable . What i tried was , connecting grounding points of the 2 racks together .
But is that enough ?
As an example of grounding each other ;
Case A > Case B > Case C > Case D
After this point do i have to turn back from Case D to Case A too ?
Well, these are my experiments .
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hi
> > I am having serious humming problem in my modular system .
> Did you monitor the Doepfer rig standalone (without any connection to
> the outside world but the powerconnectors - no MIDI!!!) and insert a
> headphone in a VCA out - it will be not extremely loud, but will be
> enough for checking. Is the hum also there without any connection to the
> outside?
> If no: There is only one serious method for tracing a hum. Disconnect
> everything in your studio, and reconnect one cable after the other and
> check after each cable, whether the hum is added. And if i say
> "everything" I mean everything. All power cables, all audio, speaker,
> lan, midi, usb whatever cable. You start with no cable connected at all.
> Then you start from the beginning:
> Poweramp to poweroutlet and speakers to Amp -> switch on -> check
> Mixer to power and to Poweramp -> check -> switch Mixer on -> check
> Reverb to power -> check -> switch Reverb on -> check
> Efx-Send to reverb in -> check
> reverb left out to fx return left -> check
> reverb right out to fx return right -> check
> and so on...
> In my studio this took a whole day, but it was worth the effort.
> BTW: To my experience today to most likely source for humming are USB
> midi or audio interfaces which are supplied by USB instead of a separate
> own powersupply.
> Florian
