A-106.1, A-106.5, A-106.6
2010-11-07 by jonathan.heslop
Do these three filters contain similar chips as they all share the 106? Is the A-106.6 just an "expander" version of the A-106.5?
2010-11-07 by Bakis Sirros
no. they seem to be quite different designs. as for the chips used, Dieter can explain further... Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Sun, 11/7/10, jonathan.heslop <jonathan.heslop@yahoo.co.uk> wrote:
From: jonathan.heslop <jonathan.heslop@yahoo.co.uk>
Subject: [Doepfer_a100] A-106.1, A-106.5, A-106.6
Date: Sunday, November 7, 2010, 7:14 PM
[Non-text portions of this message have been removed]2010-11-07 by jonathan.heslop
Thanks for the replies. I was kinda hopping they covered similar ground so my filter choice would be narrowed down! I think I will replace my 121 with the 106-6 (loads of uses, Love some of the demos, has an "alien" sound to it in some of them) my 120 with the 108 (Daft Punk filter! In some of the demos it sounds close to my old Mutator). Can anyone recommend a classy "vintage" sounding filter, a little less extreme than the 108, somthing creamy and nice? 105, 106-5, 122? Another question. Which Doepfer module acts as a combi filter? Is it the BBD module? Jonathan --- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> > jonathan.heslop wrote: > > Do these three filters contain similar chips as they all share the 106? Is the A-106.6 just an "expander" version of the A-106.5? > No, > > 106-1 is an MS20 VCF adoption (as far as I know using a combination of > three transistors and an opamp as kind of OTA). > > 106-5 is the 12db/oct state variable filter from the Oberheim SEM module > (or Formant 12dB VCF) and uses CA3080A > > 106-6 is an adaption of the Oberheim Xpander Filter which uses a CEM3372 > (different possible slopes 6//12/18/24dB) > > Florian >
2010-11-07 by Florian Anwander
jonathan.heslop wrote: > Do these three filters contain similar chips as they all share the 106? Is the A-106.6 just an "expander" version of the A-106.5? No, 106-1 is an MS20 VCF adoption (as far as I know using a combination of three transistors and an opamp as kind of OTA). 106-5 is the 12db/oct state variable filter from the Oberheim SEM module (or Formant 12dB VCF) and uses CA3080A 106-6 is an adaption of the Oberheim Xpander Filter which uses a CEM3372 (different possible slopes 6//12/18/24dB) Florian
2010-11-08 by Bakis Sirros
according to my taste, the a108 is classic vintage sounding... (moogish...?) also, the a105 has a nice smooth sound with lots of bass. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Mon, 11/8/10, jonathan.heslop <jonathan.heslop@yahoo.co.uk> wrote:
Subject: [Doepfer_a100] Re: A-106.1, A-106.5, A-106.6
Date: Monday, November 8, 2010, 1:16 AM
Jonathan
> No,
> Florian
[Non-text portions of this message have been removed]2010-11-08 by Florian Anwander
Hi jonathan > I think I will replace my 121 with the 106-6 (loads of uses, Love some of the demos, > has an "alien" sound to it in some of them) > my 120 with the 108 (Daft Punk filter! In some of the demos it sounds close to my > old Mutator). > Can anyone recommend a classy "vintage" sounding filter, a little less extreme than > the 108, somthing creamy and nice? 105, 106-5, 122? If you want to replace filter modules, then I'd recommend: * A105 as replacement for the A120 (the A105 is technically extremely close to the Mutator!). This is for the thick fat basses, great singing resonances. If you want the Kraftwerk Zongggg-Bassdrum, then use this one. * A106-5 as replacement for the A121 which should provide the classy, less extreme vintage sound. (In fact the A121 circuit is very similar to the OB-Xa 12dB Filter, where the A106 is the Oberheim SEM 12dB Filter). * A106-1 or A102 for the crude dirty stuff. Maybe also A101-1. Please keep in mind: replacing the A121 by the A106-6 does not make much sense. Though you have different slopes, the basic sound is identical. both use basically the same filter chip (A121 uses the CEM3320, where A106-6 uses CEM3372, which is a 3320 plus two VCAs). Soundwise they are quite similar! Florian Florian
2010-11-08 by achtung_999
Bakis is right.... The A108 IS great as creamy vintage sounding filter. Bear in mind that the Emphasis (resonance) and the Audio Level pots on this module go 'beyond 11'. If try the A108 with less extreme settings it sounds perfectly 'Moogish'. Grtz Ernst On Mon, Nov 8, 2010 at 1:01 PM, Florian Anwander <fanwander@mnet-online.de>wrote: > > > Hi jonathan > > > > I think I will replace my 121 with the 106-6 (loads of uses, Love some > of the demos, > > has an "alien" sound to it in some of them) > > > my 120 with the 108 (Daft Punk filter! In some of the demos it sounds > close to my > > old Mutator). > > > Can anyone recommend a classy "vintage" sounding filter, a little less > extreme than > > the 108, somthing creamy and nice? 105, 106-5, 122? > > If you want to replace filter modules, then I'd recommend: > * A105 as replacement for the A120 (the A105 is technically extremely > close to the Mutator!). This is for the thick fat basses, great singing > resonances. If you want the Kraftwerk Zongggg-Bassdrum, then use this one. > * A106-5 as replacement for the A121 which should provide the classy, > less extreme vintage sound. (In fact the A121 circuit is very similar to > the OB-Xa 12dB Filter, where the A106 is the Oberheim SEM 12dB Filter). > * A106-1 or A102 for the crude dirty stuff. Maybe also A101-1. > > Please keep in mind: replacing the A121 by the A106-6 does not make much > sense. Though you have different slopes, the basic sound is identical. > both use basically the same filter chip (A121 uses the CEM3320, where > A106-6 uses CEM3372, which is a 3320 plus two VCAs). Soundwise they are > quite similar! > > Florian > > Florian > > > [Non-text portions of this message have been removed]
