Doepfer
Module requests: Simple 48 db filter and simple Hipass
2010-12-14 by Joachim
I would like to share two module suggestion that came to my mind
while patching:
1. A simple and cheap dual 48 db filter to use with the BBD modules.
Only 2 jacks (in/out) and 1 potentiometer (frequency) per filter.
2. A simple and cheap (maybe passive) Hipass filter (80 Hz), maybe also
dual:
2 jacks (in/out) + bypass switch.
Useful for modules which generate too much low end signals.
If it would be active and dual, one 80 Hz and one 40 Hz filter would
make sense in my eyes. The latter could then be used for basses and
bassdrums and cut those frequencies that almost no loudspeaker can
handle and thus increase the headroom and help reduce some nasty
unwanted distortion effects.
What do you think?
Cheers
Joachim
Re: Module requests: Simple 48 db filter and simple Hipass
2010-12-15 by selfoscillate
hello joachim,
> while patching:
in principle a good idea, but i'm not sure if it would be
really satisfying for using it with a bbd, at least for me.
without a cv input the filter cannot follow the clock of the bbd,
which means that you need to close the filter more than necessary,
when the delay time is modulated. the a188 has a cv output for
controlling a vcf, so you can dial in just as much filtering as
necessary, which is a great feature imho. this is of course not
valid if the delay time is not modulated, but isn't that a big
part of the fun on bbd delays? often i also add a slight portion
of resonance on the vcf to emphasize the higher frequencies,
which reduces the dulling effect even more. i always use
the a108 for that, but somehow it is a bit of an overkill,
especially when you want to filter before and after the bbd
and therefore need two of them. so to make it cheaper without
omiting the useful things, i would prefer a very steep
dual vcf with reduced functions. only one cv input per channel
instead of 3, no resonance insert, no attenuators for the
audio input and a more neutral sounding and simpler filter
circuit (no need for selected transistor ladder stuff here).
it should have 48db steepness, or even 60db if possible.
i want such a module since the a188 is available and i would
buy it instantly. there was a switched capacitor dual filter in
the planning stage some years ago, for exactly this purpose,
but i believe that technical issues delayed the development
and i don't know if this project is still alive.
> dual:
a passive dual highpass filter is not a bad idea,
i just don't know how many people would buy it,
as it is a very simple circuit.
maybe you should start a poll?
best wishes
ingo
Re: [Doepfer_a100] Re: Module requests: Simple 48 db filter and simple Hipass
2010-12-16 by Bakis Sirros
agree with Ingo.
i'd also be interested in a dual 48db lowpass filter module with simple features, for use with my A188 BBD modules.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Wed, 12/15/10, selfoscillate <synaptic_music@yahoo.com> wrote:
Subject: [Doepfer_a100] Re: Module requests: Simple 48 db filter and simple Hipass
Date: Wednesday, December 15, 2010, 11:25 PM
hello joachim,
> while patching:
> dual:
best wishes
ingo
2010-12-16 by Joachim
Hi Ingo,
a CV input sounds comprehensible to me. I just thought to omit it to
keep it simple and cheap but if it is needed it is needed.
Price is not everything. ;)
The 48 db filter is more important to me than the simple highpass.
Cheers
Joachim
Am 15.12.2010 22:25, schrieb selfoscillate:
> hello joachim,
>> while patching:
>> dual:
> best wishes
> ingo
2010-12-16 by selfoscillate
yes, but it should be the version described in the red font
on top of the page, a dual 30db version which can be
coupled to work as a 60db filter. i don't know if steeper
filters push the price further up. if not, that even a
dual 60db filter would make sense imo.
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> the filter we need for our A-188 BBD modules is here (ok, in 30db or 60 db slopes):
> http://www.doepfer.de/A100_SCF.htm
> now lets see if Dieter will finalize it and bring it into production...
> www. DiN. org. uk
> www. vu-us. com
> --- On Thu, 12/16/10, Joachim <sonicwarrior@...> wrote:
> From: Joachim <sonicwarrior@...>
> Subject: Re: [Doepfer_a100] Re: Module requests: Simple 48 db filter and simple Hipass
> Date: Thursday, December 16, 2010, 9:47 PM
> Â
>       Hi Ingo,
> Cheers
> Joachim
> > hello joachim,
> >> while patching:
> >> dual:
> > best wishes
> > ingo
> > Yahoo! Groups Links
www. DiN. org. uk
www. vu-us. com
      Hi Ingo,
Cheers
Joachim
> hello joachim,
>> while patching:
>> dual:
> best wishes
> ingo
