how many stages
2010-12-26 by martindx100
hmm how many stages does the A-125 phase shifter have? and how wide is the bandwidth (at +/-1dB)? i´m probably the only one that asks these questions :) /martin
2010-12-26 by Bakis Sirros
IIRC, its 6 stages. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Sun, 12/26/10, martindx100 <martin@teknofon.com> wrote:
Subject: [Doepfer_a100] how many stages
Date: Sunday, December 26, 2010, 11:09 PM
hmm
/martin
[Non-text portions of this message have been removed]2010-12-27 by Florian Anwander
Hello Martin > and how wide is the bandwidth (at +/-1dB)? A phaser has a bandwith of maybe 100 cent within +/-1dB due to its basic principle of suppressing certain frequencies... Florian
2010-12-27 by martin sörensen
i was hoping for a wider bandwith with less phase-distortion something like figure 5 in this article http://webpages.charter.net/wa1sov/technical/allpass/allpass.html /martin
Sent: Monday, December 27, 2010 9:47 AM
Subject: Re: [Doepfer_a100] how many stages
Hello Martin
Florian
Hi Martin either me do not understand what you are asking for, or you do not understand that the basic principle of an allpass filter IS the phase shift. It is the reason why someone is building an allpass filter. Or do you mean "phase distortion" as: deviation of the "real (measured) phase shift over frequency" from "the ideal phase shift over frequency"? If the latter is the case: I fear there is no voltage controlled allpass filter that suits your (a littlebit academic) requirement. Simply because you will not be able to trim 12 variable stages to exactly the identical characteristics. You should also obey, that the page you are quoting speaks about a static phaseshifter! From the musical and sound-engineering approach, this kind of phasedistortion is irrelevant. Florian martin sörensen schrieb:
> i was hoping for a wider bandwith > with less phase-distortion > > something like figure 5 in this article > http://webpages.charter.net/wa1sov/technical/allpass/allpass.html > > > /martin
2010-12-28 by martin sörensen
hi yes it's a littlebit academic :) i'm using my doepfer in combination with a argon-krypton laser to make visuals :) the thing i'm looking for is a static wide band 90° phase shifter (90° shift from 40Hz-1kHz) /martin
Sent: Monday, December 27, 2010 11:48 AM
Hi Martin
Florian
> /martin
[Non-text portions of this message have been removed]2010-12-29 by Florian Anwander
Hi Martin > the thing i'm looking for is a static wide band 90° phase shifter (90° shift from 40Hz-1kHz) ok, then all classic audio phasers are not usable for you. Because the OTAs have a too wide variance. If you do not need voltage control anyway, then build the circuit as described in your link. May be there are other circuits to achive a static phase shift over a wide frequency range. But I do not know them. Florian
2010-12-29 by Andrew Capon
Hi Guys, I hope you all had a good Christmas. I have recently started building a small modular in a 9U A-100 suitcase. I would like to add a Analogue Systems RS35 module. On the Analogue Systems web site it states that if you add one of their modules to a doepfer system it will void both the warranty of the module and the rack. Looking at the warranty info on the Doepfer site I cannot see anything about this, apart from the worrying line "Any repair or opening of the unit carried out by unauthorized personnel (including the user) will void the warranty." which cannot be valid for modular systems surely? So I just wondered should I worry about adding this module or just go for it? Thanks for any help Andy [Non-text portions of this message have been removed]
2010-12-29 by Bakis Sirros
hi Andrew, you can of course mount AS modules into a doepfer case, but watch out, because you need a special converter ribbon power cable in order to put an AS module into a doepfer case. you can buy this cable from the AS website, or from analogue haven (US) and probably from many other modular outlets. also, some AS modules (mostly the digital ones) need +5 volts supply that the doepfer case does not supply by default. thanks, Bakis. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote:
Subject: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties.
Date: Wednesday, December 29, 2010, 12:03 PM
Hi Guys,
Thanks for any help
Andy
[Non-text portions of this message have been removed]2010-12-29 by Andrew Capon
Hi Bakis, Thanks very much for the info. As have the module and the cable in stock so I am ordering one, I will let you know how it goes. I will check the RS35 doesn't need 5V as well, my guess is that I will be ok. All the best Andy On 29 Dec 2010, at 10:55, Bakis Sirros wrote: > hi Andrew, > > you can of course mount AS modules into a doepfer case, but watch out, because you need a special converter ribbon power cable in order to put an AS module into a doepfer case. > you can buy this cable from the AS website, or from analogue haven (US) and probably from many other modular outlets. > > also, some AS modules (mostly the digital ones) need +5 volts supply that the doepfer case does not supply by default. > > thanks, > Bakis. > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > > [Doepfer_a100] group owner > > www. parallel - worlds - music. com > > www. myspace. com/ parallelworldsmusic > > www. myspace. com/ interconnectedmusic > > www. myspace. com/ memorygeist > > www. DiN. org. uk > > www. musicamaximamagnetica. com > > www. vu-us. com > > --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote: > > From: Andrew Capon <andrew.capon@zen.co.uk> > Subject: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties. > To: Doepfer_a100@yahoogroups.com > Date: Wednesday, December 29, 2010, 12:03 PM > > > > Hi Guys, > > I hope you all had a good Christmas. > > I have recently started building a small modular in a 9U A-100 suitcase. > > I would like to add a Analogue Systems RS35 module. > > On the Analogue Systems web site it states that if you add one of their modules to a doepfer system it will void both the warranty of the module and the rack. > > Looking at the warranty info on the Doepfer site I cannot see anything about this, apart from the worrying line "Any repair or opening of the unit carried out by unauthorized personnel (including the user) will void the warranty." which cannot be valid for modular systems surely? > > So I just wondered should I worry about adding this module or just go for it? > > Thanks for any help > > Andy > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed]
plus, there will be a small aesthetic issue: there will be an 1HP gap between Doepfer modules and the ASystems modules. Doepfer sells an 1HP blank plate to fill this gap. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote:
Subject: Re: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties.
Date: Wednesday, December 29, 2010, 12:59 PM
Hi Bakis,
All the best
Andy
> hi Andrew,
> thanks,
> Bakis.
> www. DiN. org. uk
> www. vu-us. com
> Hi Guys,
> Thanks for any help
> Andy
Yahoo! Groups Links
[Non-text portions of this message have been removed]2010-12-29 by James Husted
Actually it is a 1/2 a HP - doepfer sells the 1.5HP panels for that. Andrew - it is because Doepfer has their holes .3" form the edge of the metal and AS has theirs .2" from the edge. and a HP is .2" - The hole to hole spacing on the panels themselves is fine though. -James
On Dec 29, 2010, at 3:01 AM, Bakis Sirros wrote: > plus, there will be a small aesthetic issue: there will be an 1HP gap between Doepfer modules and the ASystems modules. > > Doepfer sells an 1HP blank plate to fill this gap. > > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > > [Doepfer_a100] group owner > > www. parallel - worlds - music. com > > www. myspace. com/ parallelworldsmusic > > www. myspace. com/ interconnectedmusic > > www. myspace. com/ memorygeist > > www. DiN. org. uk > > www. musicamaximamagnetica. com > > www. vu-us. com > > --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote: > > From: Andrew Capon <andrew.capon@zen.co.uk> > Subject: Re: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties. > To: Doepfer_a100@yahoogroups.com > Date: Wednesday, December 29, 2010, 12:59 PM > > Hi Bakis, > > Thanks very much for the info. > > As have the module and the cable in stock so I am ordering one, I will let you know how it goes. > > I will check the RS35 doesn't need 5V as well, my guess is that I will be ok. > > All the best > > Andy > > On 29 Dec 2010, at 10:55, Bakis Sirros wrote: > >> hi Andrew, >> >> you can of course mount AS modules into a doepfer case, but watch out, because you need a special converter ribbon power cable in order to put an AS module into a doepfer case. >> you can buy this cable from the AS website, or from analogue haven (US) and probably from many other modular outlets. >> >> also, some AS modules (mostly the digital ones) need +5 volts supply that the doepfer case does not supply by default. >> >> thanks, >> Bakis. >> >> Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist >> >> [Doepfer_a100] group owner >> >> www. parallel - worlds - music. com >> >> www. myspace. com/ parallelworldsmusic >> >> www. myspace. com/ interconnectedmusic >> >> www. myspace. com/ memorygeist >> >> www. DiN. org. uk >> >> www. musicamaximamagnetica. com >> >> www. vu-us. com >> >> --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote: >> >> From: Andrew Capon <andrew.capon@zen.co.uk> >> Subject: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties. >> To: Doepfer_a100@yahoogroups.com >> Date: Wednesday, December 29, 2010, 12:03 PM >> >> >> >> Hi Guys, >> >> I hope you all had a good Christmas. >> >> I have recently started building a small modular in a 9U A-100 suitcase. >> >> I would like to add a Analogue Systems RS35 module. >> >> On the Analogue Systems web site it states that if you add one of their modules to a doepfer system it will void both the warranty of the module and the rack. >> >> Looking at the warranty info on the Doepfer site I cannot see anything about this, apart from the worrying line "Any repair or opening of the unit carried out by unauthorized personnel (including the user) will void the warranty." which cannot be valid for modular systems surely? >> >> So I just wondered should I worry about adding this module or just go for it? >> >> Thanks for any help >> >> Andy >> >> [Non-text portions of this message have been removed] >> >> [Non-text portions of this message have been removed] >> >> > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Yahoo! Groups Links > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Yahoo! Groups Links > > >
Hi James and Bakis, Thanks for the info, I have some 2HP panels but not any 1.5HP. I can live with a small gap though. Its all ordered now. I'm looking forward to plugging a guitar into it. All the best Andy On 29 Dec 2010, at 17:57, James Husted wrote: > Actually it is a 1/2 a HP - doepfer sells the 1.5HP panels for that. > > Andrew - it is because Doepfer has their holes .3" form the edge of the metal and AS has theirs .2" from the edge. and a HP is .2" - The hole to hole spacing on the panels themselves is fine though. > > -James > > On Dec 29, 2010, at 3:01 AM, Bakis Sirros wrote: > > > plus, there will be a small aesthetic issue: there will be an 1HP gap between Doepfer modules and the ASystems modules. > > > > Doepfer sells an 1HP blank plate to fill this gap. > > > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > > > > [Doepfer_a100] group owner > > > > www. parallel - worlds - music. com > > > > www. myspace. com/ parallelworldsmusic > > > > www. myspace. com/ interconnectedmusic > > > > www. myspace. com/ memorygeist > > > > www. DiN. org. uk > > > > www. musicamaximamagnetica. com > > > > www. vu-us. com > > > > --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote: > > > > From: Andrew Capon <andrew.capon@zen.co.uk> > > Subject: Re: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties. > > To: Doepfer_a100@yahoogroups.com > > Date: Wednesday, December 29, 2010, 12:59 PM > > > > Hi Bakis, > > > > Thanks very much for the info. > > > > As have the module and the cable in stock so I am ordering one, I will let you know how it goes. > > > > I will check the RS35 doesn't need 5V as well, my guess is that I will be ok. > > > > All the best > > > > Andy > > > > On 29 Dec 2010, at 10:55, Bakis Sirros wrote: > > > >> hi Andrew, > >> > >> you can of course mount AS modules into a doepfer case, but watch out, because you need a special converter ribbon power cable in order to put an AS module into a doepfer case. > >> you can buy this cable from the AS website, or from analogue haven (US) and probably from many other modular outlets. > >> > >> also, some AS modules (mostly the digital ones) need +5 volts supply that the doepfer case does not supply by default. > >> > >> thanks, > >> Bakis. > >> > >> Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > >> > >> [Doepfer_a100] group owner > >> > >> www. parallel - worlds - music. com > >> > >> www. myspace. com/ parallelworldsmusic > >> > >> www. myspace. com/ interconnectedmusic > >> > >> www. myspace. com/ memorygeist > >> > >> www. DiN. org. uk > >> > >> www. musicamaximamagnetica. com > >> > >> www. vu-us. com > >> > >> --- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote: > >> > >> From: Andrew Capon <andrew.capon@zen.co.uk> > >> Subject: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties. > >> To: Doepfer_a100@yahoogroups.com > >> Date: Wednesday, December 29, 2010, 12:03 PM > >> > >> > >> > >> Hi Guys, > >> > >> I hope you all had a good Christmas. > >> > >> I have recently started building a small modular in a 9U A-100 suitcase. > >> > >> I would like to add a Analogue Systems RS35 module. > >> > >> On the Analogue Systems web site it states that if you add one of their modules to a doepfer system it will void both the warranty of the module and the rack. > >> > >> Looking at the warranty info on the Doepfer site I cannot see anything about this, apart from the worrying line "Any repair or opening of the unit carried out by unauthorized personnel (including the user) will void the warranty." which cannot be valid for modular systems surely? > >> > >> So I just wondered should I worry about adding this module or just go for it? > >> > >> Thanks for any help > >> > >> Andy > >> > >> [Non-text portions of this message have been removed] > >> > >> [Non-text portions of this message have been removed] > >> > >> > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed]
2010-12-30 by Bakis Sirros
yes, indeed, sorry. i never had to get such a panel that's the reason that i could not remember the exact width. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Wed, 12/29/10, James Husted <james.husted@mac.com> wrote:
Date: Wednesday, December 29, 2010, 7:57 PM
-James
> www. DiN. org. uk
> www. vu-us. com
> Hi Bakis,
> All the best
> Andy
>> hi Andrew,
>> thanks,
>> Bakis.
>> www. DiN. org. uk
>> www. vu-us. com
>> Hi Guys,
>> Thanks for any help
>> Andy
