with the modules? you might want to talk to them about this. unless maybe
you are just getting a tiny bit of bleed through and somehow your gain
staging is goofed up. that's the only other thing I could thing of besides
faulty gear.
On Thu, Jan 20, 2011 at 12:00 PM, mfretton <matt.fretton@gmail.com> wrote:
> Hi Giorgio,
> I bought the P9 suitcase new from Thomann about two weeks ago.
> Matt
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> dancemachine <dancemachine@...> wrote:
> > my 132-2 does not do this. sounds like you might have something wrong
> with
> > your system. did you get them new? if so maybe something with your power
> > supply is off. or used? if so, ask whoever you got them from. I will
> > check mine again and see if I can pop it out and figure out which version
> it
> > is as well.
> > good luck
> > -giorgio
> > On Wed, Jan 19, 2011 at 7:24 AM, Matt <matt.fretton@...> wrote:
> > > I've just got my first eurorack modular which I've been using for the
> > > first time today and have a question regarding the A-132-3 VCA. I
> > > bought two of these as they seem to offer the most flexibility in a
> > > small system, but when I patch the VCO directly into the VCA and
> > > control the amplitude with an A-140 ADSR, even with the gain control
> > > set to zero, there is a constant bleed-through of the note.
> > > To be honest, I don't completely understand the function of the gain
> > > control, as I'd have assumed that when set to zero no sound would pass
> > > through the VCA, and there appeaar to be no manual pages for it. Can
> > > anyone help?
> > > Thanks,
> > > Matt
> > [Non-text portions of this message have been removed]
