Ah no, that sounds too dirty. I use a procedure involving a power drill and
a few different bits including a Dremel filing bit, to approximate that
Cwjeman oval shape. If you go by hand you will probably end up with some
mangled-looking work with rough edges.
On Thu, Jan 20, 2011 at 6:34 AM, <david.salter@thomsonreuters.com> wrote:
> That's what needle files are for ;o)
> David Salter
> Senior Consultant
> Thomson Reuters
> O +44 (0)20 7542 2402X 52402
> M 07990562402
> david.salter@thomsonreuters.com <david.salter%40thomsonreuters.com>
> thomsonreuters.com
> From: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>[mailto:
> Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>]
> On Behalf Of Richard Scott
> Sent: 20 January 2011 14:11
> To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> Subject: Re: [Doepfer_a100] New Analogue Systems to Doepfer Cable
> Adaptor
> Great invention! Will make life much easier.
> Now if only it could make the Asys holes a bit more like the cwejman
> ones too :)
> On Thu, Jan 20, 2011 at 9:09 AM, <yahoo@doepfer.de <yahoo%40doepfer.de>>
> wrote:
> > > Hi all,
> > > In response to a couple of queries for Analogue Systems to Doepfer
> > > cable adaptors I have released a neat little product that will allow
> > > you use Doepfer type cables and just fit the adaptor to an old-style
> > > AS bus board for use with a Doepfer module/cable or will fit into an
> > > AS module so you can use it with a Doepfer cable in a Doepfer rack.
> > > There are details on my blog at
> > > http://synovatron.blogspot.com/2011/01/analogue-systems-to-doepfer
> > > -adaptor.html.
> > > If you areinterested then please contact me off-list at
> > > synovatron@btinternet.com <synovatron%40btinternet.com> <synovatron%
> 40btinternet.com> or
> > tony.steventon@talk21.com <tony.steventon%40talk21.com> <tony.steventon%
> 40talk21.com>
> > > Regards
> > > Tony Steventon
> > Excellent ! Will it be available so that we can refer interested
> > customers to your website ?
> > You should give this information also to Bob Williams (if not yet
> > happened).
> > Best wishes
> > Dieter Doepfer
> This email was sent to you by Thomson Reuters, the global news and
> information company.
> Any views expressed in this message are those of the individual sender,
> except where the sender specifically states them to be the views of Thomson
> Reuters.
