Doepfer
a111 trouble
a111 trouble
2011-02-21 by dennis henderson
hello,
one of my high end vcos doesnt stay in pitch and fluctuates when dormant. does doepfer insure modules? what should i do? also my slew limiter doesnt work with my high end vcos. please help?!
thank you,
AW: [Doepfer_a100] a111 trouble
2011-02-21 by yahoo@doepfer.de
> hello,
> thank you,
From the distance a diagnosis is difficult. Maybe the CEM3340 of the module
is faulty. Please return the module to the dealer where you purchased the
module for repair. I have problems to understand why the A-170 does not work
with with your high end VCOs. The A-170 does not "know" if it is connected
to an A-110 or A-111-1 or any other module. How do you patch the A-170.
And finally: which power supply is used ? It has to be exactly +12.0 V
and -12.0 V and I do not recommend switched power supplies. But with the
A-100 PUS2 everything should work without problems.
Best wishes
Dieter Doepfer
Re: a111 trouble
2011-02-23 by dougt55
I have some CEM3340s available if you need a new one.
Doug, synthparts.com
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > hello,
> > thank you,
> Best wishes
> Dieter Doepfer
