Doepfer
Fine-tuning A-110
Fine-tuning A-110
2011-02-23 by Fredrik Stolpe
Hello
Is it possible to fine-tune the A-110 more than the front knob allows?
Right now I have the tuning knob turned all the way clockwise but I cant
tune it correctly to other gear.
It is controlled by the dark energy, CV1 out on DE is connected to CV1 in on
A-110.
/Fredrik
Re: [Doepfer_a100] Fine-tuning A-110
2011-02-23 by Florian Anwander
Hello Fredrik
If I would be bad boy I'd say: "check the archives, we answer this twice
a month", but I am a nice one today, so....
-------- Original Message --------
Subject: Re: [Doepfer_a100] A-110 fine tune range
Date: Mon, 14 Feb 2011 09:19:53 +0100
Hi Matt
 > How easy is it to extend the range of the fine tune control on the
 > A-110 (the A-110 page on the Doepfer website says only "can be
 > modified for a wider range").
You have to reduce the value of the resistor R5. You simply may solder a
new resistor in parallel to the existing resistor. The smaller this
resistor, the wider is the range of the potentiometer.
see also http://www.doepfer.de/a110_tec.htm
Florian
Re: Fine-tuning A-110
2011-02-24 by Fredrik
Thanks
I did indeed do a search first, but found nothing :-)
F
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hello Fredrik
> From: Florian Anwander <fanwander@...>
> Hi Matt
> Florian
2011-02-24 by Sidney
Fredrick, have you noticed if you can play a regular musical scale when using your A-110 or you having trouble just to play the A-110 in tune with other synths?
At the moment don't touch anything, as Florian told.
--- In Doepfer_a100@yahoogroups.com, "Fredrik" <fredrik.stolpe@...> wrote:
> Thanks
> F
> --- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@> wrote:
> > Hello Fredrik
> > From: Florian Anwander <fanwander@>
> > Hi Matt
> > Florian
2011-02-25 by Fredrik
Hello
I can play a regular scale fine, but not tune it to other synts.
So its the R5 change then?
Regard
F
> --- In Doepfer_a100@yahoogroups.com, "Fredrik" <fredrik.stolpe@> wrote:
> > Thanks
> > F
> > > Hello Fredrik
> > > Hi Matt
> > > Florian
Re: [Doepfer_a100] Re: Fine-tuning A-110
2011-02-25 by Florian Anwander
Fredrik schrieb:
> Hello
There is the internale trimmer P6, which is intended to set the basic
center tuning.
* unscrew the A110 from the rack
* pay carefully attention, that the PCB of the module does not touch the
frame (to avoid short cuts )
* connect your MIDI CV interface to the CV In1 of the A110, and the
audio out of A110 to a monitoring system/mixer
* reassure that no other CV is fed to the A110 or the internal cv-bus.
* power up the A100
* set the tune-potentiometer on the front panel of the A110 to center
position
* feed the MIDI of an external Synthesizer with MIDI into the
MIDI-CV-Interface of the A100.
* Play a C on the external Synthesizer.
* Now listen to your external Synthesizer and the A110 and set the A110
with P6 to be in tune with the external synth.
* Switch off the A100
* remount the A100 to the rack.
* you are done.
If you want to increase the range of the Tune potentiometer anyway, then
  add a 470k Resistor parallel to R5
Florian
2011-02-26 by Fredrik
Ah, great, that's just what I was looking for, thanks a bunch Florian!
/Fredrik
> Fredrik schrieb:
> > Hello
> center tuning.
> * power up the A100
> position
> * you are done.
> Florian
