Doepfer
Identifying Patch cables
2011-03-14 by Alan
Hi folks, I wonder if anyone out there has any bright suggestions for helping me wade through this spaghetti.
Just about all my patch leads seem to be black and, without buying a load more multi-coloured ones, I'm trying to think of the best way to mark the plug of each cable with a different colour (well the same colour on each end of an individual cable if you see what I mean) so that I can quickly identify what is going where.
I thought of coloured electrical insulating tape, but I think that will just make the ends really sticky in time. At the moment I'm winding coloured sewing thread repeatedly around the ends of each cable. However, this is a bit time consuming and I don't think it's going to be a very permanent solution.
Any advice will be warmly received...
Alan
Re: Identifying Patch cables
2011-03-14 by cliffmaniam
I've used colored heat-shrink tubing on leads, but
that was when i built my own..
> Cheers,
> Alan
Re: [Doepfer_a100] Identifying Patch cables
2011-03-14 by Paul J. White
I like to use colored heat-shrink tubing to mark my cables.  You can
decorate them with a Sharpie permanent pen before shrinking to give
them extra character, too.
>Cheers,
>Alan
>Yahoo! Groups Links
2011-03-15 by James Husted
I use the colored O-rings sold by Adinfinitum with their black cables. They work much better than you would think by just looking at them.
http://www.adinfinitummusic.com/PC35mm.html
Look at the bottom of that page.
-James
> Cheers,
> Alan
2011-03-15 by blacet@blacet.com
We stock cables that use bands of colored heatshrink on black cables and
also have cables that are solid colors. I imagine you could also mix up
the two methods.
http://www.blacet.com
> -James
>> Cheers,
>> Alan
>> Yahoo! Groups Links
