Re: A100 does not power on anymore... what should I check?
2011-05-24 by Alessandro
Thanks, which kind of fuse should I purchase, ans is it easy to find?... Thank you, Alessandro --- In Doepfer_a100@yahoogroups.com, Richard Horsman <richyho@...> wrote:
> > It is probably the fuse inside the Doepfer case. Mine has blown many times - usually after adding a new module or two. It seems that the power supply gets used to delivering a certain amount of power and if that changes the fuse blows. Well, that's what it seems like to me anyway which is why I keep a box of 10 fuses in my patchlead box at all times! > > Hope this helps > > > > > > Hello, > my A100 does not power up. > I changed the power cord, socket, everything that keeps connected the A100 to the power supply but it is still dead. > > What should I check before sending it back :( > > Many thanks, > Alessandro > > [Non-text portions of this message have been removed] >
