Doepfer
Re: Another newbie question - use of A-190 GATE output
2011-08-22 by zaum
Yes, by patching modules in with the patch cord into the main CV or gate jack on the front of the module causes you to you disconnect the module from listening to the bus. Not all the modules that could in theory follow the signals on the bus actually do. It's mostly your more basic modules like VCOs and ADSRs. You can find out which do by simply seeing if your ADSR lights up when MIDI comes in or your VCO changes pitch if you only connect the audio out to your mixer and no cable to your CV in. Typically you just patch your module normally and there is no need to worry but if your MIDI to CV is sending to the bus then you can save a few cables and still not worry.
The warning people mentioned that is dangerous is trying to install a second module that sends voltage to the bus on the same bus as another module doing that.  Typically you have your MIDI to CV module doing the sending to the bus. The second not good for you module would have to be something like a second MIDI to CV converter that uses the bus or maybe the special Doepfer Bus Access module. It's not that likely that you will connect one of them since not so many modules send CV to the Bus but Doepfer wants you to know that you shouldn't do that so you don't do it by mistake and then something goes wrong. Not very many modules send signals to the bus and for better or worse not all modules that could pay attention to the bus actually do. It's an only sometimes utilized feature.
nick
2011-08-23 by Ton Akveld
Hi group,
As I seem to understand, I can safely use the GATE OUTPUT of the A-190 MCVS as the INPUT for the Reset Trigger of the A-145 LFO.
I connected the two, but I get no result whatsoever.
Can anyone advice?
Thanks in advance,
Ton
--- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@...> wrote:
> It seems so :-)
> Everybody: ThanX!
> --- In Doepfer_a100@yahoogroups.com, Zoë Blade <zoe@> wrote:
> > In other words, go for it. ;)
2011-08-24 by jakobsweb
Hi Ton,
try connecting A-145 reset in with A-160/161 clock outputs for better rythmical results or the output of a A-140 envelope. Not sure if the gate signal itself - even though you may technicly connect - offers the results you are looking for ... just a thought.
yours
Jakob
> Hi group,
> Can anyone advice?
> Thanks in advance,
> Ton
> --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote:
> > It seems so :-)
> > Everybody: ThanX!
2011-08-24 by Ton Akveld
Hi Jakob,
Thanks for the 'thought', I appreciate it.
1. I think you're right on not obtaining the desired result.
2. As I am in the process of 'building' a A-100 system and financial restrictions prohibit me from buying more than one module a month, I didn't get to purchasing a A-160 yet. It will however get a higher rating on my to-have list.
Ton
--- In Doepfer_a100@yahoogroups.com, "jakobsweb" <jakob.paulussen@...> wrote:
> Hi Ton,
> yours
> Jakob
> > Hi group,
> > Can anyone advice?
> > Thanks in advance,
> > Ton
> > > It seems so :-)
> > > Everybody: ThanX!
AW: [Doepfer_a100] Re: Another newbie question - use of A-190 GATE output
2011-08-24 by yahoo@doepfer.de
> Hi group,
> Can anyone advice?
> Thanks in advance,
> Ton
Each positive edge of the gate will cause the A-145 to reset and start from
zero into positive direction. For details please refer to the A-145 user's
manual.
Best wishes
Dieter Doepfer
2011-08-25 by Ton Akveld
Dear Dieter,
Thank you for your reply.
I'll feed the A-145's signal to the oscilloscoop and see if I can detect the change between with or without trigger.
Rest assured I study the manuals as good as I can before posting questions to the group.
Warm regards,
Ton
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > Hi group,
> > Can anyone advice?
> > Thanks in advance,
> > Ton
> manual.
> Best wishes
> Dieter Doepfer
