Doepfer
WTB: Dark Time
WTB: Dark Time
2011-12-05 by Matt Fretton
Thought I'd check here to see if anyone has a Dark Time to sell before
I go to Thomann. I'm in London UK. Matt
A-117 modification
2012-02-01 by istari
hi
i just tested around the A-117 oscillator part. i played with the
trim-pots and now
thinking about adding some external pots instead of them to pitch
adjust them from frontside.
i simply added also some lfo voltage to the middle pin and found some
little response to that.
did anymody did that before? i also thinking if something else then
the 250k pot will sweep
the oscillators more deeper.
wonder if the CD40106BE is doing the osc sounds or if it belongs to
the digital noise. as far
as i think both unites are kind of seperate on one pcb.
the oscillators do some nice drony sounds beside of their main aim
for cymal percussions.
felix
Re: A-117 modification
2012-02-04 by Tim
The 40106 next to the two trimpots contains all the oscillators: the trimpots are used for the oscillators for the '2 oscillators' output; the other 4 oscs are fixed frequency. The other 40106 is used for the digital noise - one section for the oscillator, the others for inverting or simply buffers.
Tim
