8-step sequencer with direction control
2012-05-28 by henkbloedvlek
Is there any change on making a Doepfer 1x 8-step sequencer for the A100 systems like the Plan B Milton model 21c ??? I find the A-155 is taking to much space.
2012-05-28 by Ton Akveld
And another exotisch one: http://www.makenoisemusic.com/RENE.html But I think Zoë arduino based one is a real charm. I am trying to figure out if it can be made into a product. Question for Zoë: is it expandable to more steps? GreetZ to all, Ton --- In Doepfer_a100@yahoogroups.com, Martin Klang <mars@...> wrote:
> > > 10hp algorithmic gate sequencer, up to 32 steps! > http://www.rebeltech.org/modules/stoicheia/ > > /m > > On 28 May 2012, at 12:53, henkbloedvlek wrote: > > > Is there any change on making a Doepfer 1x 8-step sequencer for the A100 systems like the Plan B Milton model 21c ??? > > > > I find the A-155 is taking to much space. > > >
2012-05-28 by Martin Klang
10hp algorithmic gate sequencer, up to 32 steps! http://www.rebeltech.org/modules/stoicheia/ /m
On 28 May 2012, at 12:53, henkbloedvlek wrote: > Is there any change on making a Doepfer 1x 8-step sequencer for the A100 systems like the Plan B Milton model 21c ??? > > I find the A-155 is taking to much space. >
2012-05-28 by Zoë Blade
> But I think Zoë arduino based one is a real charm. Thanks! > I am trying to figure out if it can be made into a product. I've been wondering the same thing myself. :D > Question for Zoë: is it expandable to more steps? Yes, the 16 steps are pretty arbitrary. Nina and I are still working out what would be the best interface for it (digitally controlled tempo, pattern length, pattern selection and copying/pasting/transposing/rotating, and entering notes, rests, slides and accents). I don't like the idea of scrolling or layers of menus, so it'll either be buttons and LEDs and potentially up to hundreds of steps, or buttons and a single big LCD and up to 16 steps, all visible on-screen at once. It should be pretty easy to implement DIN sync in and out too, plus make an eight channel drum machine version, so it could be a really neat set of devices. We're hoping to at least make a kit available, maybe in the form of an Arduino shield at least, but it depends how much interest there is. I'm hoping to eventually work my way up to a fully fledged multi-channel step sequencer with a few different channels of pitched notation, drums and tempo synced LFOs... but I tend to run away with ideas quite a bit! All the best, Zoë.
Ah, that's great news! I won't be in your way. The more steps the merrier for my part ;-) A multi-channel one for starters, designed with the 'run away ideas' in mind, it will be than! You have my full support. Keep up the good work you two wizards ;-) --- In Doepfer_a100@yahoogroups.com, Zoë Blade <zoe@...> wrote:
> > > But I think Zoë arduino based one is a real charm. > > Thanks! > > > I am trying to figure out if it can be made into a product. > > I've been wondering the same thing myself. :D > > > Question for Zoë: is it expandable to more steps? > > Yes, the 16 steps are pretty arbitrary. Nina and I are still working out what would be the best interface for it (digitally controlled tempo, pattern length, pattern selection and copying/pasting/transposing/rotating, and entering notes, rests, slides and accents). I don't like the idea of scrolling or layers of menus, so it'll either be buttons and LEDs and potentially up to hundreds of steps, or buttons and a single big LCD and up to 16 steps, all visible on-screen at once. > > It should be pretty easy to implement DIN sync in and out too, plus make an eight channel drum machine version, so it could be a really neat set of devices. > > We're hoping to at least make a kit available, maybe in the form of an Arduino shield at least, but it depends how much interest there is. I'm hoping to eventually work my way up to a fully fledged multi-channel step sequencer with a few different channels of pitched notation, drums and tempo synced LFOs... but I tend to run away with ideas quite a bit! > > All the best, > Zoë. >
2012-05-28 by Florian Anwander
I have to admit, that I find 8-steps always too limited. The least minimal phrase I can stand with is a 4/4 bar with 16th notes, vulgo a 16step sequencer (more would be better). I could imagine a modular sequencer, which consists of an adress generator (like the A154), and various chainable module. E.g two 8-step modules which can be played either A-B or A-A-A-B. Also there could be several kinds of modules like switches for gate/trigger, potentiometers for non tonal cv, 12position switches for tonal cv's. etc pp. Florian
