Fwd: AW: [Doepfer_a100] Re:AND EVEN MORE info about the super filter! from doepfer.
2002-10-17 by bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] Re: info about the super > filter! from doepfer. > Date: Thu, 17 Oct 2002 14:15:49 +0200 > > > -----Urspr�ngliche Nachricht----- > > Von: bakis Sirros > [mailto:synth_freak_2000@yahoo.com] > > Gesendet am: Donnerstag, 17. Oktober 2002 09:47 > > An: dieter doepfer > > Betreff: Fwd: [Doepfer_a100] Re: info about the > super filter! from > > doepfer. > > > > > > --- ringmod45 <ringmod45@yahoo.com> wrote: > > > To: Doepfer_a100@yahoogroups.com > > > From: "ringmod45" <ringmod45@yahoo.com> > > > Date: Thu, 17 Oct 2002 02:55:40 -0000 > > > Subject: [Doepfer_a100] Re: info about the super > > > filter! from doepfer. > > > > > > hi bakis, > > > > > > the Erwik filetr is based on the low cost Curtis > 3372 combined > > > VCF/VCA that is also found in the budget > Sequential Prophet-600,Akai > > > AX80 and the absolutely superb Oberheim Matrix > 12. > > > to the best of my knowledge, there were only 15 > possible variations. > > > > > > 1 pole Low > > > 2 pole Low > > > 3 pole Low > > > 4 pole Low > > > 1 pole High > > > 2 pole High > > > 3 pole High > > > 2 pole Band > > > 4 pole Band > > > 2 pole Notch > > > 3 pole Phase > > > 2 pole High + 1 pole Low > > > 3 pole High + 1 pole Low > > > 2 pole Notch + 1 pole Low > > > 3 pole Phase + 1 pole Low > > > > > > do you mean to say that Doepfer will add more > then the ones mentioned above. > > Yes, definitely. The frequency response curves on > the provisional A-107 page > show already many filter types that were not > available for the ERWIK or > Matrix12/Xpander filter. > > > > the filter will require at least a 2 digit > display like the A113 > > > subharmonic generator. the first digit could the > filter type and the > > > second digit would be the memory position for > the filter type from > > > the vc filter selection input. on the outer > edges the display, you > > > could have the dual pushbuttons like the A113 to > go up or down. now > > > you are probably wondering , how would get > fifteen locations out of a > > > simple single digit display. you use the digits > 1 to 9 for the one to > > > nine positions, you use the 0 for the number ten > position, then you > > > add a dot at the bottom left position of the > digit for the digits > > > over ten, i.e .1 is for eleven, .2 is for twelve > etc. etc. same goes > > > for the memory position for the vc filter select > input position. > > > > > > to program the sequence of filter types for the > vc filter selection > > > input you press the 2 vc filter selection input > push buttons at > > > once , then the vc filter selection display > starts flashing at the > > > number one position. you then press the up or > button on the left side > > > for ther filter type value. to set the second vc > filter select memory > > > value you hit the down button to set it the 2 > position then you hit > > > the up or down on the left side for the filter > type. you keep > > > repeating the steps to complete the sequence of > the filter types. > > > once you are done programming, you push the two > vc filter selection > > > input buttons at once and the flashing memory > positon stops flashing > > > and away you go. > > > > > > there is an example of what i mean for the > display the files section. > > > hope this helps on the logic side of the vc > filter selection input. > > Thank you for this suggestion how to select a filter > and how to define the > filter sequence. We even think about different > filter sequences that available > in the module as it is very long-winded to define a > new filter sequence (but > somewhere we have to stop otherwise we will have the > same problem as for the > touch sensor keyboard: too many different > suggestions that increase the price > and postpone the delivery date month by month). > > We will probably use a 3-digit display so that not > only number but even filter > abbreviations (e.g. "3h" for 3-pole high pass, "2b" > for 2-pole band pass, "4L" > for 4-pole low pass or "hnL" for high pass/notch/low > pass combination) could be > used. But maybe it is a problem to find a useful > abbreviation for more complex > filters (like the "tooth" filter on the A-107 page). > > Best wishes > Dieter Doepfer > Doepfer Musikelektronik GmbH > http://www.doepfer.de > email: hardware@doepfer.de > ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com
