MCV-24 battery replacing
2012-11-01 by Zoë Blade
Hi! Just to make sure, should I put a 3.6 volt battery in the MCV-24? It looks like it's probably already been replaced once, and the battery currently in there doesn't seem to specify a voltage. It looks like the circuit board specifies 3.6 volts, so I just wanted to make sure there wasn't a last minute change of plan in the spec or anything. :) Thanks, Zoë.
