Doepfer
Re: Maximum Current Draw
2013-01-23 by isoldeandisobelle
Thank you very much, that is reassuring, I was working on the assumption that the maximum total was 650ma.
Best wishes
--- In Doepfer_a100@yahoogroups.com, achtung_999  wrote:
> Way within the limits. The Doepfer 6U cases are rated 1,2A I believe.
> Ernst
> On Wed, Jan 23, 2013 at 12:09 PM, isoldeandisobelle <
> isoldeisobelle@...> wrote:
> > Hi,
> > In my 6U case, the current usage of all modules installed amounts to the
> > 650ma limit, this includes the A-113 Sub Harmonic generator, which is rated
> > at 30ma, I have not included the 5v low cost adapter in this total -
> > although it it installed.....am I still within safe limits?
> > Kind regards
Re: [Doepfer_a100] Re: Maximum Current Draw
2013-01-23 by achtung_999
Actually, it was 650mA for the cases with the old powers supply. Do you
have a PSU 2 or 1 in the case? The PSU 2 is a round transformer core and
PSU 1 is a small black plastic transformer. PSU 2 is 1200mA the PSU 1 is
650mA.
On Wed, Jan 23, 2013 at 12:43 PM, isoldeandisobelle <
> Best wishes
> > Ernst
> > > Hi,
> the
> rated
> > > Kind regards
AW: [Doepfer_a100] Re: Maximum Current Draw
2013-01-23 by yahoo@doepfer.de
> Best wishes
It depends upon the built in power supply ! The old version A-100TN12 had
only 650mA (manufactured until about 2001), the new version A-100PSU2 has
1200 mA.
The label at the power supply inlet should tell you the type of supply. If
there is no label it's probably the old version wit 650 mA only. To be on
the safe side you have to look at the power supply. It there is a black
ashlar-formed  block it's the A-100NT12 with 650mA. If there is a ring-core
transformer it's the new A-100PSU2 with 1200mA
Best wishes
Dieter Doepfer
