116 + 137 + 137-2 + 136 how much overlap between modules?
2013-02-07 by sweetsynthchuck
Hi guys, First post here, I am very much intent on getting a combination of the units above for processing duties, my question is there any overlap between the four selected? Thanks
2013-02-07 by Florian Anwander
Hello and welcome! > I am very much intent on getting a combination of the units above for > processing duties, my question is there any overlap between the four > selected? Let me describe it soundwise: The A116 can sound similar to a simple fuzz box, but has many setting, which can make the sound "thin". I like it for non-synth signals and for classic TB303-Filter-through-distortion-box sounds. The A136 can create sounds which remind to hardsync, but also normal "fuzz box" sounds. So there is an overlap with the A-116. The A137 is basically four stages of A136 in series, with less parameters per stage, but the count of stages adds parameters. It doesn't really do the fuzz box sounds, but it does all the hardsync-like waveshaping sounds in "cubing". The A-137-2 makes a supersaw from a normal saw. It has nothing to do with the other three modules. The A116, A136, and A137 require that you thinking goes away from subtractive synthesis. Those modules add(!) something to the sound, while usual filters subtract(!) somthing from the sound. To get the interesting results, you have to feed smooth and "dark" sounds into those modules. Of course you can use those modules for alread bright signals, but then they do not add a dramatic change to the signal. Example: sending a rectangle wave into one of those modules is quite senseless, as a the distortion of any waveform will result finally in a rectangle. To be honest: 80% of the sounds from a A116 or A136 can be achieved with a simple guitar stomp box. In the opposite the A137 (used in the right way) can create very unique sounds. I recommend the A137. Florian
2013-02-07 by Zoë Blade
Interesting. Are there any examples of these modules being used anywhere? I'd love to hear what they sound like. By way of reciprocation, I made a demo of the A-188-1B and 1-188-1D last night. When you listen to them, it becomes clear how the B version is a better flanger, and the D version is a better delay. You can hear them at https://soundcloud.com/doggiedogster/sets/doepfer-a-188-1-comparison
Ah, the official pages have examples of the 136, 137 and 137-2, just not the 116: http://blog.andreaskrebs.de/2010/08/07/doepfer-a-136-distortionwaveshaper-example/ http://www.doepfer.de/A137.htm http://www.doepfer.de/a1372.htm
Hi Florian, Thank you for the very in-depth response, That's exactly what I want to do is "Add" to my source signal before further processing ie filtering..etc ok regarding your last statement (stompboxes), the reason I am interested in the units suggested is for there tweak ability and shaping abilities of static waveforms (even modulation options via cv which is a huge plus). I first set my eyes on a few stomp boxes but in terms of tweak ability and shaping waveforms I fear they may be a one trick pony and not flexible enough. I had originally planned to get a A-138D and a few stomp boxes but in terms of flexibility I opted not to and after some research came to the modules listed in original post. I may consider the 138d if stomp boxes will give me more or alternative types of distortion that cannot be achieved with modular units, I am fascinated with distortion, pushing things to there limits to create harmonics be it subtle or extreme. My goal is to build a fx chain in a beauty case for my vco shaping duties , I have 32hp to fill. so any recommendations for my specific task is welcome. the 136 is defiantly on my to buy list (flexible and from the pictures of the actual wave shaping , it looks like the perfect candidate) so I have 24hp free for other modules. I have in mind the 137 + ? im not sure what else. Also for my specific task do you really feel the 116 is not really needed if I pick up a 136? Thanks ps Thanks Zoe I did check out all the demos while researching (I research a lot before any purchases) :) --- In Doepfer_a100@yahoogroups.com, Florian Anwander wrote:
> > Hello and welcome! > > > > I am very much intent on getting a combination of the units above for > > processing duties, my question is there any overlap between the four > > selected? > Let me describe it soundwise: > > The A116 can sound similar to a simple fuzz box, but has many setting, > which can make the sound "thin". I like it for non-synth signals and for > classic TB303-Filter-through-distortion-box sounds. > > The A136 can create sounds which remind to hardsync, but also normal > "fuzz box" sounds. So there is an overlap with the A-116. > > The A137 is basically four stages of A136 in series, with less > parameters per stage, but the count of stages adds parameters. It > doesn't really do the fuzz box sounds, but it does all the hardsync-like > waveshaping sounds in "cubing". > > > The A-137-2 makes a supersaw from a normal saw. It has nothing to do > with the other three modules. > > > The A116, A136, and A137 require that you thinking goes away from > subtractive synthesis. Those modules add(!) something to the sound, > while usual filters subtract(!) somthing from the sound. To get the > interesting results, you have to feed smooth and "dark" sounds into > those modules. > Of course you can use those modules for alread bright signals, but then > they do not add a dramatic change to the signal. Example: sending a > rectangle wave into one of those modules is quite senseless, as a the > distortion of any waveform will result finally in a rectangle. > > To be honest: 80% of the sounds from a A116 or A136 can be achieved with > a simple guitar stomp box. In the opposite the A137 (used in the right > way) can create very unique sounds. I recommend the A137. > > Florian >
Hello, If you have the A-137, you do not need the 136 or 116 (that is my opinion). Regarding the tweakability: the main parameter for all distortion devices in the world is the level of the input signal. Feed a sine into a VCA, modulate that VCA with an envelope, feed that signal into the stompbox -> it will be the same as if you would tweek the "foldinglevel" at the A136 or 116 I even never use modulation on the A137, but I always use fix parameter settings on the A137 and modulate the inputsignal with an VCA. This has the big advantage, that the output signal level stays the same. Florian Am 07.02.2013 17:07, schrieb sweetsynthchuck:
> Hi Florian, > > Thank you for the very in-depth response, > > That's exactly what I want to do is "Add" to my source signal before further processing ie filtering..etc > > ok regarding your last statement (stompboxes), the reason I am interested in the units suggested is for there tweak ability and shaping abilities of static waveforms (even modulation options via cv which is a huge plus). > > I first set my eyes on a few stomp boxes but in terms of tweak ability and shaping waveforms I fear they may be a one trick pony and not flexible enough. > > > I had originally planned to get a A-138D and a few stomp boxes but in terms of flexibility I opted not to and after some research came to the modules listed in original post. > > I may consider the 138d if stomp boxes will give me more or alternative types of distortion that cannot be achieved with modular units, I am fascinated with distortion, pushing things to there limits to create harmonics be it subtle or extreme. > > > My goal is to build a fx chain in a beauty case for my vco shaping duties , I have 32hp to fill. > > so any recommendations for my specific task is welcome. > > the 136 is defiantly on my to buy list (flexible and from the pictures of the actual wave shaping , it looks like the perfect candidate) so I have 24hp free for other modules. > > I have in mind the 137 + ? im not sure what else. > > > Also for my specific task do you really feel the 116 is not really needed if I pick up a 136? > > > Thanks > > ps > > Thanks Zoe I did check out all the demos while researching (I research a lot before any purchases) > > :) > > > > > > > > > > --- In Doepfer_a100@yahoogroups.com, Florian Anwander wrote: >> >> Hello and welcome! >> >> >>> I am very much intent on getting a combination of the units above for >>> processing duties, my question is there any overlap between the four >>> selected? >> Let me describe it soundwise: >> >> The A116 can sound similar to a simple fuzz box, but has many setting, >> which can make the sound "thin". I like it for non-synth signals and for >> classic TB303-Filter-through-distortion-box sounds. >> >> The A136 can create sounds which remind to hardsync, but also normal >> "fuzz box" sounds. So there is an overlap with the A-116. >> >> The A137 is basically four stages of A136 in series, with less >> parameters per stage, but the count of stages adds parameters. It >> doesn't really do the fuzz box sounds, but it does all the hardsync-like >> waveshaping sounds in "cubing". >> >> >> The A-137-2 makes a supersaw from a normal saw. It has nothing to do >> with the other three modules. >> >> >> The A116, A136, and A137 require that you thinking goes away from >> subtractive synthesis. Those modules add(!) something to the sound, >> while usual filters subtract(!) somthing from the sound. To get the >> interesting results, you have to feed smooth and "dark" sounds into >> those modules. >> Of course you can use those modules for alread bright signals, but then >> they do not add a dramatic change to the signal. Example: sending a >> rectangle wave into one of those modules is quite senseless, as a the >> distortion of any waveform will result finally in a rectangle. >> >> To be honest: 80% of the sounds from a A116 or A136 can be achieved with >> a simple guitar stomp box. In the opposite the A137 (used in the right >> way) can create very unique sounds. I recommend the A137. >> >> Florian >> > > > > > ------------------------------------ > > Yahoo! Groups Links > > > >
2013-02-07 by achtung_999
If you have the A-137, you do not need the 136 or 116 (that is my opinion). > > I totally agree with Florian. I owned an A116 that I sold and I still have an A136 that I hardly use.... The A137-1 is for my feeling far superior! [Non-text portions of this message have been removed]
