A-187 manual
2013-03-24 by Syndromeda
Hi, I don't see a link on the Doepfer's website to a A-187 manual, or don't I need it, is it that simple to use? Thx, Danny
2013-03-24 by flosynth
--- In Doepfer_a100@yahoogroups.com, "Syndromeda" <syndromeda@...> wrote: > > Hi, > I don't see a link on the Doepfer's website to a A-187 manual, or don't I need it, is it that simple to use? > Thx, > Danny > Hi Danny, On site all the modules do not have a PDF manual, even if sometimes some modules deserve a little PDF. I was very interested in this module, I do not have that yet, but in fact it is no more complicated than a stomp box, the list of effects is on the site, from there 2 inputs and 2 outputs and 4 CV to modulate the effect parameters desire to change these parameters is shown at the bottom of the screen (and also in the list that is on the site) you can also change these settings manually, as described on the module, the upper row of buttons for manual settings and below to adjust the intensity of the VC. I think it must be very easy to take care of quickly
Hi Danny, Well, I have just ordered one, hope to receive it soon and maybe it is as you say...just as easy as a stompbox. Thanks for the help. Danny --- In Doepfer_a100@yahoogroups.com, "flosynth" <fleur.de.florence01@...> wrote:
> > > > --- In Doepfer_a100@yahoogroups.com, "Syndromeda" <syndromeda@> wrote: > > > > Hi, > > I don't see a link on the Doepfer's website to a A-187 manual, or don't I need it, is it that simple to use? > > Thx, > > Danny > > > > Hi Danny, > > On site all the modules do not have a PDF manual, even if sometimes some modules deserve a little PDF. > > I was very interested in this module, I do not have that yet, but in fact it is no more complicated than a stomp box, the list of effects is on the site, from there 2 inputs and 2 outputs and 4 CV to modulate the effect parameters desire to change these parameters is shown at the bottom of the screen (and also in the list that is on the site) you can also change these settings manually, as described on the module, the upper row of buttons for manual settings and below to adjust the intensity of the VC. > > I think it must be very easy to take care of quickly >
--- In Doepfer_a100@yahoogroups.com, "Syndromeda" <syndromeda@...> wrote: > > Hi Danny, > Well, I have just ordered one, hope to receive it soon and maybe it is as you say...just as easy as a stompbox. > Thanks for the help. > Danny > > --- In Doepfer_a100@yahoogroups.com, "flosynth" <fleur.de.florence01@> wrote: > > Danny is uhh you :-) Florence is me ^ ^ You'll see it's really easy to navigate, I forgot the three small black buttons, "effect" down t up is to move through the menu and select the desired effect, and bypass ben ..... you know You give new have fun
2013-03-25 by Florian Anwander
Hello, On 24.03.13 10:35 , Syndromeda wrote: > I don't see a link on the Doepfer's website to a A-187 manual, or don't I need it, is it that simple to use? Yes it is very simple to use. The table with the algorithms is all you need. The DSP is a OEM module from another manufacturer (you can se it as piggyback pcb in the pictures). This plugin-module is used by several other manufacturers, maybe there is a manual from another brand. Florian
2013-03-25 by syndromeda@telenet.be
I did not know this Florian, thanks for the info. Do you also happen to know which other manufacturers use this? At first glance I could not find anything. Cheers, have a nice day, ------------------------------------------------------ Danny Budts info@syndromeda.be www.syndromeda.be ----- Oorspronkelijk bericht ----- Van: Florian Anwander <fanwander@mnet-online.de> Aan: Doepfer a100 <Doepfer_a100@yahoogroups.com> Verzonden: Mon, 25 Mar 2013 08:39:30 +0100 (CET) Onderwerp: Re: [Doepfer_a100] A-187 manual Hello, On 24.03.13 10:35 , Syndromeda wrote: > I don't see a link on the Doepfer's website to a A-187 manual, or don't I need it, is it that simple to use? Yes it is very simple to use. The table with the algorithms is all you need. The DSP is a OEM module from another manufacturer (you can se it as piggyback pcb in the pictures). This plugin-module is used by several other manufacturers, maybe there is a manual from another brand. Florian
2013-03-28 by istari
hello i just tryed the gate to switched trigger cable and it works great to trigger my sq10 from the A-100. but sometimes i want that the sq10 to work as a master clock device. i recognized that the s-trigger cable does not work in the other direction. is there any chance to build a cable that goes from s-trigger as input to A-100 gate? i usally use a trigger modifier module for that but i hoped to just can do it with a cable. best felix
2013-03-28 by Florian Anwander
Hello Felix The "S" in s-trigger stands for a passive "switch", the "V" in v-trigger stands for an active voltage. This voltage has to come from somewere. So you need supplypower for the conversion S-Trigger to V-Trigger. That is why you need a module like the trigger modifier for it. You cannot do it with a simple cable. Florian Am 28.03.2013 10:24, schrieb istari:
> hello > ... > is there any chance to build a cable that goes from s-trigger as > input to A-100 gate? > > i usally use a trigger modifier module for that but i hoped to just > can do it with a cable. > > best > felix >
2013-03-28 by yahoo@doepfer.de
Please look at the A-100 DIY page: 4.2.12. Modifying the A-165 trigger inverter/modifier for S-Trig input Best wishes Dieter Doepfer P.S. All news we will show at the Musikmesse in Frankfurt (April 10-14) are listed since yesterday on the news page of our website.
> -----Ursprungliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von istari > Gesendet: Donnerstag, 28. Marz 2013 10:24 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] inverse s-trigger cable > > > hello > > i just tryed the gate to switched trigger cable and it works great to > trigger my > sq10 from the A-100. > > but sometimes i want that the sq10 to work as a master clock device. > i recognized that > the s-trigger cable does not work in the other direction. > > is there any chance to build a cable that goes from s-trigger as > input to A-100 gate? > > i usally use a trigger modifier module for that but i hoped to just > can do it with a cable. > > best > felix > > > ------------------------------------ > > Yahoo! Groups Links > > >
