Doepfer
Doepfer A-143.4
Doepfer A-143.4
2013-04-04 by isoldeandisobelle
I love the Doepfer A-143.4 and can not really find something else comparable on the market.... but, is there a modification to this unit that can make it produce a sine wave, instead of the square/triangle?
Good luck at Musikmesse Dieter!
Re: [Doepfer_a100] Doepfer A-143.4
2013-04-04 by Florian Anwander
Hi
Am 04.04.2013 09:48, schrieb isoldeandisobelle:
> square/triangle?
You may check
http://www.timstinchcombe.co.uk/index.php?pge=a110
It is a mod for the A110, but it should work as addition for the 143-4 too.
Florian
Re: Doepfer A-143.4
Thank you very much to the both of you for your replies.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hi
> > square/triangle?
> You may check
> Florian
