Doepfer
Hard synchronising VCO's
2013-06-23 by anoop.sahal
I have not seen this feature in the VCO's of Doepfer but old analogue synths had it.
It would help improve FM synthesis.
Hard synchronising VCO's  would be a desirable feature if the phase at which each VCO is at is continuously adjustable (1 to 179 degrees) , before locking it.
I do not have a system yet so apologies is the above post is stupid.
Anoop
Re: [Doepfer_a100] Hard synchronising VCO's
2013-06-23 by Florian Anwander
Hello
The A110 and A111 VCOs do have Hard-Sync.
But for FM you will prefer the soft sync (it locks on overtones). The
A111 does provides it direct (socket 'S-Sync'), the A110 has it prepare
internall, but there is no socket on the outside. I added a switch to
one o my A110s, so I can switch between hard or softsync.
Florian
> Regards
> Anoop
Re: Hard synchronising VCO's
2013-06-24 by isoldeandisobelle
...this is interesting, Florian - I did not know that the A - 110 had this feature, is there a schematic on how to add this feature?
Kind regards
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hello
> Florian
> > Regards
> > Anoop
Re: [Doepfer_a100] Re: Hard synchronising VCO's
2013-06-24 by Florian Anwander
Hello
Am 24.06.2013 12:58, schrieb isoldeandisobelle:
http://www.doepfer.de/a110.htm say:
"...For more detailed information please look at the user's manual
A110_man.pdf. In addition the A-110 service manual is available as an
example for the A-100 service manual that is available at extra charges.
which links to: http://www.doepfer.de/a110_tec.htm
Florian
Thank you very much for the reply - I will look in to this.
Best wishes
> Hello
> Florian
