A-166 odd or not?
2013-09-20 by mark@umcorps.com
Just picked up a used A-166 which is behaving in a way I didn't expect. Not sure if it is faulty or if I haven't quite understood how the module normalisations are supposed to work.
Both sections work fine on their own - the logic operations are as expected.
But if I patch the upper logic processor inputs, the resulting outputs are also present at the lower section outputs, even though the LEDs on the lower outputs are not showing any activity.
So if I put 2 clocks into input 1 and 2 of the first section and take the output from, say, XOR on the second section I get the same outcome as I would do from taking the output from section 1s XOR output, even though the output LEDs are only active for section 1.
Is that right?
Mark
