Newbie question about A-190-1 and A-145
2013-10-23 by Rupert Lally
Hi, I've just bought myself the Doepfer a-100 basis system mini, plus a few additional modules in a P6 case and I have a couple of (probably obvious) questions. Firstly, when I trigger the modular via the A190 midi cv interface, there is a click that precedes any envelope sent out, even with the LPF filter completely closed I can still hear - it almost seems like clock CV bleeding through in to the audio signal - if that's possible - Does anyone know a solution to this? Secondly, when triggering a VCO via the LFO going straight out through the VCA I can hear the LFO pulse bleeding through as well (slightly ahead of the VCO signal), even on low range setting - is this normal? Many thanks, Rupert Lally Sent from my iPad
