Doepfer
Can I connect all 3 BUS boards in a P9 case ?
2013-11-17 by nicholas.buckley@ntlworld.com
Hi everyone,
I understand that, using the special cable ( A-100 BC ? ), you can connect TWO bus boards together. Without using e.g. A-185, is it possible to connect ALL THREE BUS boards within a single P9, such that the CV / Gate control from my A-190-2 will be available across the entire system?
I think it's most likely that my A-110's and A-140's will occupy the lower and middle BUSses, but should I wish to expand onto the upper BUS, is there a way to get the CV / Gate control onto the upper BUS?
Or, I suppose, turning the question on it's head, is it always a good idea to limit BUS-aware modules to a single BUS, with a link to a second BUS being the clear exception rather than the rule.
Either way, is there a practical ( safe ? ) limit to the number of modules that can be 'driven' by the A-190-2 ?
Best wishes,
Nick,
Cardiff, UK.
RE: [Doepfer_a100] Can I connect all 3 BUS boards in a P9 case ?
2013-11-17 by Nicholas Buckley
Hi James,
Nice idea re: power cables.
As for making your own header/jumper cables, the Doepfer documentation talks
explicitly about linking TWO busses together.
If L=Lower, M=Middle and U=Upper and assuming A-190 is mounted on the Middle
bus,  then something tells me that you could get away with M->U and M->L by
fabricating a Y-cable.
Permutations such as M->U->L or M->L-U would probably be OK too with the
appropriate cabling.
I rather think that any kind of loop: M->U->L->M should be avoided.
Kind regards,
Nick
  _____
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of James Husted
Sent: 17 November 2013 18:22
Subject: Re: [Doepfer_a100] Can I connect all 3 BUS boards in a P9 case ?
The busses can be connected, there is no electrical reason why not. The main
thing to avoid is plugging more than one gate or CV SOURCE into the bus. If
you don't have the special little header/jumper cables to connect them then
the other easy way is to just cross connect two unused 16-pin headers with a
spare power cable. MAKE SURE TO HAVE CORRECT POLARITY before you turn on the
juice of course.
It is fairly easy to make one of those header/jumper cables. Just look for
some of those two position shunts used on older computer hard drives etc.
Many of them have access to the metal connection inside (a notch on the top
to connect test probes etc) and all you have to do is solder a wire there
and make your own.
James Husted
Designer, Synthwerks LLC
www.synthwerks.com
james@synthwerks.com
synthwerks@me.com
On Nov 17, 2013, at 8:50 AM, nicholas.buckley@ntlworld.com wrote:
Hi everyone,
Best wishes,
Nick,
Cardiff, UK.
2013-11-17 by James Husted
The busses can be connected, there is no electrical reason why not. The main thing to avoid is plugging more than one gate or CV SOURCE into the bus. If you don't have the special little header/jumper cables to connect them then the other easy way is to just cross connect two unused 16-pin headers with a spare power cable. MAKE SURE TO HAVE CORRECT POLARITY before you turn on the juice of course.
It is fairly easy to make one of those header/jumper cables. Just look for some of those two position shunts used on older computer hard drives etc. Many of them have access to the metal connection inside (a notch on the top to connect test probes etc) and all you have to do is solder a wire there and make your own.
James Husted
www.synthwerks.com
synthwerks@me.com
Hi everyone,
Best wishes,
Nick,
Cardiff, UK.
