dieter's answer to ringmod's suggestions...
2002-11-08 by bakis Sirros
DIETER SAYS: "Hi Bakis, this is my comment to one of the A-154 suggestions (you may publish it in the forum): > the module looks good , but i see the need for a few > adjustments. the 4 led's to tell which direction it is moving in, is > very confusing, especially in a live context with dim lights. > > my suggestion is to have 8 horizontal led's which indicate the > direction the sequencer will follow. here are the possibilites I cannot see the reason for this additional LEDs as you have the 8 LEDs of the A-155 that show the mode while the sequence is running. And how do you want do display the CV addressed step mode ? From my point of view you can recognize much faster which mode is selected if only one LED is used to display the mode. For your suggestion you have to look at the 8 LEDs and your brain has to "calculate" which mode this will be. This takes much more time than to look at one LED. For my opinion your display type is more confusing and takes more time to see which mode is selected. And the "light show" is available at the A-155 LEDs. But for us it is no problem to realize this type of display if the users would prefer this (it's only different PIC programming of the LEDs). > chasing one another to the right for forward movement > chasing one another to the left for reverse movement > chasing one another to the right then back to the left for pendulum > mode 1 and flashing the last leds twice for pendulum mode 2 > random is just what it means a random diplay of its position. > > the plus side to this is its cheap and would provide a cool light > show as well. hint blue led's. also you could have the VC Clock cycle > the led's in time like the A145, 146 and 147 lfo's. > > the voltage controlled clock should have a variable pulse width with > an input and manual pot. This will probably be available (we prepare a new A-154 sketch with this additional feature) ...... > here is the Feature i crave the most!! > > Two 10 pin connectors on on the back so you can have a VC analog > selection for 2 sequencers to have 16 steps. This causes a technical problem as it is not possible to turn one of the A-155 off (one of the 8 steps is always active). One would have to modify the circuit so that it is possible to turn one of the A-155 off (e.g. using the inhibit pins of the multiplexer). This would require electronical knowledge: I'm not sure if it makes sense to offer a module that requires electronical modifications. I tuppose most of the A-100 user's would not be able to do these modifications on the pc boards. But it would be possible to add this feature (i.e. 2 inhibit outputs to address the 2 A-155) if the user is able to do the required modifications on the A-155 boards. Another solution would be the usage of a VC switch (A-150) that switches the CVs and triggers/gates between the two A-155 modules. The A-154 needs not to know if only one A-155 or two A-155 are connected as he simply generates the address signals A0, A1, A2 and the two inhibit signals as well. If the inhibit signals are not used no modifications are required for the A-155. If the inhibit signals are used the A-155 have to be modified. Or one of inhibit signals is used to control a A-150 VC switch. My suggestion: internal (i.e. on the pc board) the two inhibit signals will be available for those customers who are able to do the required modifications for the A-155. In addition one inhibit signal (e.g. called A3) is available at the front panel (jack socket) to drive an optional A-150. Best regards Dieter Doepfer Doepfer Musikelektronik GmbH http://www.doepfer.de email: hardware@doepfer.de" ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? U2 on LAUNCH - Exclusive greatest hits videos http://launch.yahoo.com/u2
