On 30 May 2014, at 10:21, "Zoë Blade zoe@bytenoise.co.uk [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:
>> While some devices do calculate the tempo *and* use it, many do not.
>> What they do is simply "count clocks" and use that as a time base.
>> If there were only 2 clocks per beat then swing would work easy enough.
>> ...but trying to sort out the timing for 24 ticks ( or whatever the actual figure is)
>> to produce a swing in the slave machine 12 of those ticks would have to
>> be drawn out, and the other 12 sent quicker to compensate.
>> Generally getting the BPM from midi clock just isn't accurate enough
>> for syncing.
> Right. So the simpler devices that just count the clock pulses shouldn't really have a problem. As they're not trying to do anything fancy such as extrapolate a tempo, they're just counting and incrementing and chugging along quite happily, blissfully unaware that the fluctuations in timing might signify swing or a tempo change or anything else.
> The only thing I've really done with MIDI clocks and DIN sync clocks in recent years is hook up my partner and I's homebrew step sequencer to an MCV-24. Our sequencer just counts the clock pulses coming in from the MCV-24, which in turn is translating the MIDI clock signal it gets from Reaper. I threw in some tempo changes, and it worked perfectly, to my ears. Counting DIN sync pulses is really quite a neat solution. It's simple and elegant.
> All the best,
> Zoë.
> Posted by: =?iso-8859-1?Q?Zo=EB_Blade?= <zoe@bytenoise.co.uk>
> Yahoo Groups Links
