Doepfer
A-165 modification
A-165 modification
2014-07-04 by Dennis Verschoor
Hello,
I'd love to do two modifications to my a-165.
- first i want a 10 volt trigger out.
- second i want a shorter trigger period of 4ms
Anyone know what resistors i should change?
Dennis
Music at: http://www.mono-poly.nl
AW: [Doepfer_a100] A-165 modification
2014-07-07 by yahoo@doepfer.de
> Hello,
> Cheers,
> Dennis
The capacitors C1 and C1' (factory value 47nF) define the pulse width. As
47nF corresponds to about 50 ms you may use e.g. 4n7 or 3n9 or 3n3 to obtain
a width in the 4ms range.
The high state output voltages of the module are close to +12V (unloaded).
If that's too high use a simple voltage divider made of 2 resistors.
Best wishes
Dieter Doepfer
