Doepfer
Frequency Shifter
Frequency Shifter
2014-11-14 by Neil Kagan
In the absence of a new A-126, does anyone have an idea of how to create a frequency shifter using existing Doepfer modules?
Neil
AW: [Doepfer_a100] Frequency Shifter
2014-11-14 by yahoo@doepfer.de
> Neil
I think that's not possible because of the required dome filter. That's a special allpass filter that shifts all frequencise from
about 50Hz to 10 kHz of the incoming audio signal by 90 degrees). The rest of the job could do two ring modulators, the A-143-9 and
mixers.
But we are working on an new frequency shifter (A-126-2) that will include a squelch circuit. The A-143-9 or any other quadrature
oscillator (e.g. the planned A-101-4) can be used as external quadrature oscillator (i.e. no built in oscillator).
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Frequency Shifter
Thanks Dieter,
I know it's a stupid question but will the external oscillator be patched via the front panel? I don't want to have to make a connection between them internally.
Neil
> On 14 Nov 2014, at 14:56, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> > Neil
> mixers.
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] Frequency Shifter
2014-11-17 by yahoo@doepfer.de
> Thanks Dieter,
> Neil
Yes, there will be two sockets for sine and cosine input. But there will be probably also a normalling solution (i.e. internal
connection between the A-143-9 or A-101-4 and the frequency shifter module via the switching contacts of the sine/cosine sockets).
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Frequency Shifter
2014-11-17 by Neil Kagan
Amazing thanks! There's a lot of excitement over this from people I've spoken to, as it's such a unique sound but they want to get a Doepfer module to do it with.
Neil
On 17 Nov 2014, at 09:19, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
>> Thanks Dieter,
>> Neil
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
2014-11-17 by achtung_999
That's great, that begs for misuse :D
Curious what sounds that will result in....[?]
Just what I was thinking!! Imagine running the A-137-1 into it, or a graphic VCO...
> On 17 Nov 2014, at 11:39, achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
