> On 1 Dec 2014, at 02:08, achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Then again, a normal mixer that does not amplify (for instance the doepfer a138a/b) is also a unity gain mixer if you turn all the channels you are using to the maximum setting.
>> On Sun, Nov 30, 2014 at 10:22 PM, james.husted@mac.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
>> The module you want is a unity gain mixer/summer - it is like a mixer without the level controls. Intellijel designs makes one called the Unity Mixer for US$75 (on Analogue Haven - http://www.analoguehaven.com/intellijeldesigns/unitymixer/ ). It is a dual 3-in 1 out summer that is normalized together so can make a 6-in one out summer. It is also only 2HP wide. Very useful if you have VCOs with only one V/Oct Cv in and you want to drive it with a sequencer and transpose from a keyboard for instance.
>> -James
>> James Husted, Designer, Synthwerks LLC • www.synthwerks.com • james@synthwerks.com • info@synthwerks.com
>>> On Nov 30, 2014, at 12:20 PM, florian anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
>>> Hello David
>>>> So would buffered mults work in the same way but with no risk?
>>> No buffered mults wouldn't work at all. They are the opposite of a mixer
>>> (think them as 7 aux sends of a mixer, with send volume turned fully up).
>>> A mixer is a mixer. Thats it.
>>> A multiple in your planned setup is simply a shortcut between two
>>> outputs and one or several inputs. Using them may work some way, as long
>>> as you are feeding them with the outputs of equal modules. Feeding them
>>> with the outputs of different modules may cause troubles; but as long as
>>> they are built like Doepfer ones (a serial resistor in the output path),
>>> you won't kill them. The troubles may be in the dimension of "one signal
>>> suppresses the other signal in a significant way" or "signal A causes a
>>> frequency damping of signal B". This may be fun or may be an unwanted
>>> effect.
>>> Florian
>>> Posted by: florian anwander <fanwander@mnet-online.de>
>>> Yahoo Groups Links
