Re: [Doepfer_a100] A129-1/2
2014-12-12 by Scott Rogers
JUST as an option, I use the electroharmonix V256. No voltage control (I
haven't looked at the module so I don't know what it can do) but it
sounds fantastic as long as you have a good mic (don't use a 57 or
58, get something like an AT2020). WAY better than microkorg, Korg M3
(built in) and several others I've tried.
Scott
At 08:45 AM 12/12/2014, you wrote:
Scott
And for me it is not about doing the voice vocoding... there are so much more possiblities..
 Alas.. alas...
On Fri, Dec 12, 2014 at 2:44 PM, achtung_999 < heinrich.himmelwasser@gmail.com> wrote:
So it was you... that was the last one...
It went offline at Thomann a few weeks back.
I should have been faster.Â
Ernst
On Fri, Dec 12, 2014 at 1:56 PM, David Kellett davidkellettwoulf@yahoo.com [Doepfer_a100] < Doepfer_a100@yahoogroups.com> wrote:
Â
Ernst - I bought one a couple of weeks ago from Thomann after I got the other bits on eBay. When I bought mine I think they had 2 more left.........
I set them up on Wednesday night - mic into Fireface and then out via light pipe to ES3 and then back through ES6 with the Vocoder output. It is brilliant!! The Direface ES3 means I don't need something to boost the mic up to A100 signal strength. I was using a Waldorf XT as the carrier signal - the polyphony and the ability to get moving, bright sounds made me use the XT for my first experiments. I'm hoping to replace my voice with Shortwave radio sounds - but there is no signal in my studio as it is in the basement. I'm gonna need a very long arial!!Â
David
www.movingisliving.co.uk
Sent from my iPhoneÂ
On 12 Dec 2014, at 11:24, achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] < Doepfer_a100@yahoogroups.com> wrote:
Â
For years I have been thinking about getting the vocoder heart of the system...
Recently I checked it out again and noticed to my horror that it's not being made anymore...Â
Is there going to a follow up to this module(s)? Or am I damned to get it 2nd hand?
I'm quite bummed out about this. The A129-1/2 is totally unique.
Greetings,
Ernst
