Doepfer
VCO A-110-1 Problem ?
2015-01-07 by deladriere@gmail.com
Hi there
I have Doepfer A-110-1 Standard VCO
I power it with the Doepfer DIY-Kit 1200mA
I cannot get the A-110 to work correctly :it constantly jumps from one frequency to another. (even unplugged with no entries connected)
you can listen to the example here unplugged
At first I thought I needed to warm it a little bit but even after a few hours it keeps doing the same.
I also suspected the CV bus so I removed the jumper but nothing helps
I have the impression that the module never worked & so far it is totally useless
Any advice ?
Many thanks in advance
AW: [Doepfer_a100] VCO A-110-1 Problem ?
2015-01-07 by yahoo@doepfer.de
> Hi there
> entries connected)
> https://www.dropbox.com/s/t02uihfw14adc83/VCO_problem.mp3?dl=0
> Any advice ?
I suppose that it's a problem with the supply. Please check if the voltages +12V and -12V are OK. Maybe the transformer does not
have sufficient power. If the supplies are OK please return the module to the dealer where you purchased it for repair/replacement.
Best wishes
Dieter Doepfer
