Doepfer
AW: [Doepfer_a100] WTB Doepfer Drehbank.
2015-02-05 by yahoo@doepfer.de
> BTW I see the 8 CV inputs are factory configured. Anybody know how easy it is to make them all just CV inputs, no foot
> controllers etc?
If you are familiar with electronics that's possible but a lot of work. You have to interrupt the signal that leads from each
potentiometer to the measuring input of the ADC-unit and replace it by a socket for the external CV. And you have to make sure that
the external voltage is in the range 0...+5V (i.e. a protection circuit for each input). Negative voltages and voltages beyond +5V
will destroy the electronics. If you only need the CV-to-Midi function (i.e. no potentiometers and the housing) I'd recommend the
DIY/OEM products Pocket Electronic or USB64. If you want a module I'd recommend the A-192-1.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] WTB Doepfer Drehbank.
2015-02-07 by groups@andrewmcnaughton.com.au
Thanks Dieter. So no just plugging Eurorack directly into those inputs (even with a modified cable) I suppose!
I have been looking at the A192-1 - I already own a pocket MIDI thing, which I gather is the same underlying interface board. I wonder if I could just "add" some external CV inputs to that thing ...
