Doepfer
Dark Energy I behaving strangely. CEM3394 defective? If so, replace it myself?
2015-02-15 by manhaterde@yahoo.de
Today I noticed a strange behavior in my Dark Energy I. I noticed a constant modulation of the cutoff frequency. It sounds like the cutoff is being modulated by an audio-rate square wave. Of course I ruled out any bleed by whatever internal CV sources are available. The modulation won't go away.
Maybe the CEM3394 has turned bad? If so, I have a Simmons SDS-800 which I don't use which has 4x CEM3394 chips inside. Is there anything I have to consider when swapping the chip myself (apart from the obvious need to re-calibrate various parameters in the Dark Energy)?
kind regards
Frank
AW: [Doepfer_a100] Dark Energy I behaving strangely. CEM3394 defective? If so, replace it myself?
2015-02-16 by yahoo@doepfer.de
> kind regards
> Frank
If it's a faulty CEM3394 replacing the circuit should fix the problem.
Best wishes
Dieter Doepfer
AW: AW: [Doepfer_a100] Dark Energy I behaving strangely. CEM3394 defective? If so, replace it myself?
2015-02-18 by yahoo@doepfer.de
> Thanks Mr. Doepfer!
> Since I will have to remove the Supply/Interface Board to reach the DE's CEM3394, I assume I have to remove the 3.5mm
> jack screws on the top of the casing? What's the proper tool to do so?
> thanks so much and kind regards
> Frank
You need a suitable socket wrench (about 11 mm). Even pliers may be used but this increases the risk to damage the case and nuts.
Best wishes
Dieter Doepfer
Re: [Doepfer_a100] Dark Energy I behaving strangely. CEM3394 defective? If so, replace it myself?
2015-02-18 by Florian Anwander
Am 18.02.2015 um 09:50 schrieb yahoo@doepfer.de [Doepfer_a100]:
Hello Frank
If you don't have a wrench set, then you may use a universal  plier with
a protecting adhesive tape like seen here:
http://fa.utfs.org/diy/monopoly_mirage/images/100-0055_IMG.jpg
Florian
2015-02-18 by Zoë Blade
The hex nuts?  Nina made a tool just for that if anyone's interested: https://twitter.com/nr2097/status/565815987178831872  You can 3D print that to get a handy little device to screw in hex nuts with, without scratching the faceplate.
All the best,
Zoë.
