Doepfer
The untunable A-110s
2015-08-21 by roland.schregle@gmail.com
Hi all, hi Dieter (if you're listening :^),
I'm new to modular synthesis and got my hands on a used Doepfer A-100 base system which worked fine until this year's scorching summer, or at least I didn't notice any issues before; not sure if there's a connection with the high temperatures we've been experiencing.
I know the A-110 VCO's tuning/tracking is often discussed to death on forums, but I appear to be stuck with a pair of untunable A-110's.
The two A-110 VCOs in my kit (rev.3, > 15 years old?) have both drifted WAY out of tune. I followed the calibration procedure on Doepfer's website, but after 4 attempts, I've given up: both VCOs barely track over 1 octave, and the scaling pots on both (P7) are at their limits. But get this: they are at opposite ends of their respective limits, i.e. the tracking of these VCOs is actually divergent. I find that pretty weird.
Just to make sure, I've calibrated the A-190 MIDI-CV interface accurate to 1mV, and checked that the supply voltages are within spec too. I even checked the relative values of the critical resistors R1, R1', R2, R3, R3'; they are all within 0.1% as required.
I'm at the end of my rope. Is it time to replace the aged opamps, or should I just replace both modules outright?
Many thanks,
--GT
AW: [Doepfer_a100] The untunable A-110s
2015-08-21 by yahoo@doepfer.de
I'm sorry about your problems with the A-110. Please contact our A-110 specialist directly: Matthias Marass (keyboards@doepfer.de).
He has tested more than 10000 A-110 over the last 20 years and is responsible for the service of the A-110. Maybe the internal
transistor heaters are defective and the CA3046 have to be replaced. But that's only a guess.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Freitag, 21. August 2015 10:39
> Betreff: [Doepfer_a100] The untunable A-110s
> untunable A-110's.
> 0.1% as required.
> Many thanks,
Re: AW: [Doepfer_a100] The untunable A-110s
2015-08-21 by Dr. Roland Schregle
On Fri, 21 Aug 2015 10:46:05 +0200, yahoo@doepfer.de [Doepfer_a100]
Thanks for referring to Matthias, Dieter.
FYI, I tried swapping the CA3046's, but that made no difference. I also
checked the tempco voltage, and it was at around 0.63V as per the
calibration requirements.
I hope Matthias can drop me a hint. Many thanks,
--Roland
"END OF LINE" [MCP, 1982]
