RE: [Doepfer_a100] Fwd: Fw: about the triple switch module.
2002-12-02 by David Salter
Certainly if it provides functionality not available on the electronic switches (150/151). David Salter Reuters Consulting Tel: +44 20 7542 2402 Mob: +44 7990562402 Fax: +44 20 7542 2699
From: bakis Sirros [mailto:synth_freak_2000@yahoo.com]
Sent: 02 December 2002 14:32
To: Doepfer_a100 group
Subject: [Doepfer_a100] Fwd: Fw: about the triple switch module.
> From: "Dieter Doepfer" <hardware@doepfer.de>
> To: "bakis sirros" <syrros@ath.forthnet.gr>
> Sent: Monday, December 02, 2002 4:10 PM
> Subject: AW:
> > > -----Ursprüngliche Nachricht-----
> > > Von: bakis sirros
> [mailto:syrros@ath.forthnet.gr]
> > > Gesendet am: Samstag, 30. November 2002 01:42
> > > An: Dieter Doepfer
> > > Betreff: Re:
> > > hi dieter,
> > > if this 4HP switch module doesn't need expert
> knowledge in order to be
> > > connected with the a155/a154 then please
> manufacture this module!
> > > can you explain how this switch module would be
> connected to the
> a155/a154
> > > combi???
> > I think we will make it pending from the customers
> inquiries if we
> manufacture
> > such a module (only a triple switch with with a
> small pc board and 3
> 10-pin
> > connectors, that have to be connected to the A-155
> and A-154: one leads to
> the
> > potentiometer/trigger boards of the A-155, one to
> the "old" control
> section of
> > the A-155, one to the A-154. The switch position
> determines if the A-155
> is
> > controlled by its old control section (e.g. for
> graphic VCO applications)
> or by
> > the A-154. But Christian is confident that the
> A-154 will even work with
> audio
> > frequencies but he cannot say if it will work up
> to 5kHz, 10kHz, 20kHz
> > The internal clock generator will not work in
> audio range (only up to
> about 100
> > Hz) but this is no disadvantage as you need in any
> case a 1V/octave
> precision
> > VCO for graphic VCO applications (e.g. A-111) and
> the internal clock
> oscillator
> > could not do this job.
> > Best regards
> > Dieter Doepfer
> > Doepfer Musikelektronik GmbH
> > http://www.doepfer.de
> > email: hardware@doepfer.de
THIS IS IT LIST.
ANY OPINIONS??SHOULD THIS MODULE BE MANUFACTURED?
bakis.
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now. http://mailplus.yahoo.com
To unsubscribe from this group, send an email to: doepfer_a100-unsubscribe@yahoogroups.com
Visit our Internet site at http://www.reuters.com
Get closer to the financial markets with Reuters Messaging - for more
information and to register, visit http://www.reuters.com/messaging
Any views expressed in this message are those of the individual
sender, except where the sender specifically states them to be
the views of Reuters Ltd.
