A-190-4 help me! Please :)
2015-10-09 by Mike Gray
Hi folks, relatively new to all, of this. What's my problem? Horrendous tracking with the A190-4. Tested system with Kenton and it's fine. VCOs animodule lil monster and make noise STO calibrated fine on that. A couple of days later, running from both logic and ableton the tracking is all over the place. A-190-4 set to defaults, manual says don't alter the tun scale settings ( which aren't at 001 as per described in manual, but at 054, and 121 -I assume some factory calibration ??) Results ? Tracking is horrendous Twiddling the settings gives no better results, reset to initialisation and no better, back to where I started. Now before I sell this (and I have to say great Doepfer gear) and buy an es3 what am I doing wrong ? Or am I likely to have a faulty unit? Ps I don't have a volt meter to measure what's coming out of the A190-4 and can't really justify the money So options are return to base since it's less than two months hold or you my new friends may have the secret answer to my problems. Yours with respect, mike. Cheers. :) Sent from my iPad
